Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 02-19-2006, 09:58 PM
bikeo bikeo is offline
Arrow 98 TSP driver side window off track??
About half way up the window begins to canter to one side and jams. I then must assist it with my hand to keep it straight and to close properly.Is this a common problem on 98's? Any pointers? Just wanted to get a little insight before I tear the door apart. Thanks.
Old 09-22-2006, 06:41 PM
midirtriders.com midirtriders.com is offline
Re: 98 TSP driver side window off track??
I have the same issue with mine. also driverside..
I thought I read a thread on here somewhere about it.. but cant seem to find it now.. maybe someone will help us out..
Old 09-24-2006, 08:24 AM
bmcf bmcf is offline
Try ........http://www.automotiveforums.com/vbul...t=window+track
I had the exact same issue with my drivers side window.
I adjusted the top of the front track & silicone lubed the tracks. Now the window is not perfect but darned near.
The remaining slop in the window is due to flex in the regulator arm.
At this point I'm not too worried about it as the siliconed tracks allow the window to slide the last 1/4" closed that the regulator arm flex allows.
Does that make sense?
Good luck!
Old 09-24-2006, 10:00 PM
it does for me..
thanks for the help..
Old 10-01-2006, 01:46 PM
mike232 mike232 is offline
I had the same problem and the window would very go up. With time, it would go up even slower. Finally, I caved in and had to have the "lifter" replaced. Now it works, but it was not a "cheap" job.
