Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-19-2006, 10:04 PM
cc95stang cc95stang is offline
95 mustang
i have a 95 stang automatic,the car just started running ruff,runs like the car is a 5speed thats in 5th gear when you should be in 3rd.fuel mileage is bad.any help would be greatly appreciated thanks chris
Old 03-15-2006, 01:24 AM
scottmuirhead scottmuirhead is offline
Re: 95 mustang
check fuel injectors run a bottle of cleaner through 1/4 tank of gas at an idle, if problem persists check fuel filter and replace it they are cheap and well worth it
Old 03-15-2006, 03:07 AM
NJH_Habitatpro NJH_Habitatpro is offline
Send a message via AIM to NJH_Habitatpro Send a message via Yahoo to NJH_Habitatpro
Re: 95 mustang
You may also want to check spark plugs and or vacuum hoses. You can check the hoses with some water and soap. Rub it on the hoses and if the car bogs down then that is where the leak is. Had same problem with mine just mine is a 5 speed.
Old 03-15-2006, 03:36 AM
KimMG KimMG is offline
AF - Advisor
Re: 95 mustang
Check to see if there are any codes.
Old 03-23-2006, 04:33 PM
riffraff613 riffraff613 is offline
Re: 95 mustang
i have a 1990 mustang gt 5.0 . i replaced the transmission with a new transmission I still have slippage. it feels like it dosent want to catch . what should i do to find out what is wrong . it is AOD .I just put in a new 3.73 gear and pinion in the rear end in and it ran great for a few days . then it started feeling like it was just raising the rpms up but not catching . please help i am frustrated and going broke trying to make this car perform the way i want it to
Old 08-24-2006, 11:27 PM
Re: 95 mustang
how do u find out the codes,do i have to put it on a comp?
