Old 02-19-2006, 08:45 PM
1991HB 1991HB is offline
Send a message via AIM to 1991HB
car is dying
ok I posted a thread on here with the subject ECU code 10...don't listen to any of that. I went and looked at my friends car...it's throwing a 3 code and 20 code. We went and drove it around the block and while driving it, it all of a sudden just died. Another thing is when you turn the turn signals on sometimes they will work normal and sometimes they will flash hella quick and than back to normal. So what's the deal here, why does it just die and why do the turn signals do this???
Old 02-19-2006, 11:13 PM
pokey69 pokey69 is offline
Re: car is dying
the signals flashing quickly might mean you have a loose wire in one of the signals. when one isnt working, the other will pulse very quickly.
Old 02-22-2006, 05:49 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: car is dying
Yeah if the power isnt distributed evenly between the signals (I.E. one is disconnected) then it will put more power to one and make it flash faster.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 02-22-2006, 06:53 PM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
Re: car is dying
or your light bulb is just out. thats what happened to my friends civic but basicly the same as what them said above
Old 02-23-2006, 03:14 PM
Rayser34 Rayser34 is offline
Send a message via Yahoo to Rayser34
Re: car is dying
never think 1 problem is related to the other cars dont brake 1 part at a time need more info on the car dieing . does it start back up does it only die when hot cold or just not in the mood?
Old 02-23-2006, 04:31 PM
lxndr's Avatar
lxndr lxndr is offline
AF -Advisor
Re: car is dying
Code #3 is for the MAP sensor, code 20 is for the O2 sensor.
If it's randomly dying you probably have a bad MAP sensor or a vacuum leak to the sensor. A faulty O2 sensor will usually just send the ECU into limp mode, but it will still run.
Old 02-23-2006, 04:38 PM
FrodoGT's Avatar
Re: car is dying
Yeah if you lose vaccum to the MAP, itll die with the quickness....or if its just bad.
Current project:
Rio Red 91 hatch.
