Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 02-19-2006, 07:25 PM
flowtownfrowman flowtownfrowman is offline
Question engine swap 1.6 to a 3.0
Will it fit? i know it will be expensive .... I have the B 2 door coop version its a Xe but i just cant squeeze enough hp out of that small engine to keep me happy.
Old 02-20-2006, 04:41 AM
fugiot's Avatar
fugiot fugiot is offline
Send a message via MSN to fugiot
Re: engine swap 1.6 to a 3.0
I hope you meant 2.0, because you'd have a hell of a time with a 3.0.
The 2.0 will fit. See the Sentra README thread.
SR20 powered SE-R: 60mph-6.2 sec., 1/4mi.-14.7 sec.
VG30 powered Maxima SE: 60mph-7.8, 1/4mi.-15.8 sec.
Don't make me ANGRY
Or I will kick you in teh NUTS
Your NUTS will feel teh steel toe
Teh steel toe that has been in teh snow
I will rip off yuor pants and kick yuo in teh nuts
My steel toe will stick to yuor nuts
And I will swing yuo around by yuor nuts as I do a Hurricane kick
Old 02-20-2006, 11:54 AM
nismo_pilot nismo_pilot is offline
Send a message via AIM to nismo_pilot
maybe he's talking about the vg30 from teh maxine? the 3.5 will fit in the new b15 chassis with some fabbing although idk about the 3.0 into an older chassis, the b15 is wider and longer so there may be some issues
hotshot also has a turbo kit for the ga16de that bolts on and runs mid 13's straight out the box
Old 02-22-2006, 01:12 AM
too many miles for a turbo
Old 02-22-2006, 04:06 AM
fugiot's Avatar
Is there something wrong with the motor? Cause if not, I doubt you have too many miles on it.
Just put an SR20 in it anyway.
Don't make me ANGRY
Old 02-23-2006, 11:00 AM
could always replace head gasket and rings, freshen up the valvetrain and then turbo would go good on it with any amount of miles, its a low boost kit so you wont need pistons or rods.....sr20 might be cheaper
Old 02-26-2006, 01:12 AM
SR20B12's Avatar
SR20B12 SR20B12 is offline
what yr . is your B12? does it have the Ga16I or the E-16?
yes you could fit a mai engine in it. but it's not like swapping a SR, CA or a GA in it. the VQ or VG are
goning to be all custom swaps. from wiring tranny, and engine mounts,and all the plumming. My 2 Cents. don't do it. I would choose one of the ohter swap I listed above. the best bang for the buck would be the CA18DET into the coupe .. sense this was stock in all the coupes' but the american ones. the Ca will be around 175HP with stock turbo.and use the same mounts. and a doner car is a 88-89 Pulsar SE for all your stuff. but the DET engine and the ECU and MAF.
chip
B12 coupe w/SR20DE
91 AE92 Daily Grinder.
Old 02-26-2006, 09:53 PM
B12 Ftw!!
