Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 02-19-2006, 07:15 PM
ckrumm24 ckrumm24 is offline
1995 SL2 barely starts..help!!!
I have a 1995 Saturn SL2 that barely starts, I dont know much about cars so i'll try to explain whats happening.
About 2 weeks ago I went to start my car and it would take about 5-10 seconds of turning the key until it finally turned over and started. I thaught maybe it could of been a battery issue because when this happened the clock and radio station would reset. I continued using my car when I HAD to and then yesterday it wouldn't start at all it would just make some noise when trying to start it ( like a weak starting sound with some bad sounds ) but then it would never turn over. I figure I'd try jump starting it to see if it was the battery. It didnt work at all. Then one of my friends suggested giving it gas (without jumping it) while i tryed starting it and that worked. So if I give it gas i can get it to start now. Also if my car doesnt sit for a long time (like over an hour) after I turn it off the car will start immedietly when I start it again withuot giving it gas or the delay. What are your oppions on what the problem/s could be and how much dose it cost to replace.
Other Notes: *sometimes when it starts my ABS light comse on but not all the time this is probably a different problem all together im guessing)
*when I open the hood it looks like the engine is shaking more than it should
* the belt that is visible makes some noise
* I noticed that when I shift the car from Drive into Nuetral that you can actually hear it swithcing ( it seems like its to loud as if there mgiht be a problem)
* In general the car runs fine once it starts
thanks for any help
I apologize for any confusion/vauge i really know nothing about cars.
Old 02-19-2006, 10:09 PM
Mines69Olds's Avatar
Mines69Olds Mines69Olds is offline
Send a message via AIM to Mines69Olds
Re: 1995 SL2 barely starts..help!!!
The fuel problem sounds like a fuel pressure regulator. The fuel pump must work but I've heard are a problem. You may also want to check for a new fuel filter if it hasn't been changed. If the car hasn't been checked or serviced lately you might want to have it done. Test the battery to be sure, the belts probably need changed, and check all the fluids to make sure everything is clean and doesn't need changed.
Matt
1969 Olds Cutlass
1985 Olds Cutlass
2000 Ford Ranger
2001 Jeep Cherokee Sport
Old 02-20-2006, 12:00 AM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
ok, my guess is maybe your belt tensioner is bad. the squeak is kind of a give away to me with the fact that the battery seems to be dying off with the abs light coming on. i mean you could have multiple issues, but id check with the belt tensioner first because all of those items can relate back to the belt tensioner, alternator, and/or battery.
now as of the excessive shaking, the top anchor mount (upper engine mount on passenger side) is probably bad. they tear over time.
Old 02-20-2006, 12:01 AM
Cat Fuzz Cat Fuzz is offline
Bad spark plug wires can do weird things to an engine. Check the wires on the coil pack end. Corrosion likes to get in there and mess stuff up.
