Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 02-19-2006, 07:10 PM
pokergypsy pokergypsy is offline
something weird spark plug poping out?
from the hole whear the spark wire? can some help?hi i got a? got a 1998 sebring convert 25v6 one of the spark plug wires pops out?when you push it in the car missis and makes a poping noise and you can feal the plug or something pushing the wire when you put your hand on it? now if you take the wire out a little its fine? just a little mis and some oil leaking
Old 02-19-2006, 08:17 PM
Oldengineer Oldengineer is offline
Re: something weird spark plug poping out?
Sounds like the spark plug is busy unscrewing itself out of the engine. Remove the spark plug boot and tighten the plug back down. Then replace the boot.
Regards:
Oldengineer
Old 03-08-2006, 08:32 PM
acampinoob acampinoob is offline
Sounds to me like the spark plug tube seal. It is the thing that seperates the spark plug and spark plug wire from the valves and the oil in your valve cover. You said it had an oil leak- if is there oil leaking ON TO the spark plug wire, the tube seal is bad. If this is so, you may have a bad spark plug tube seal and they are simple to replace. There shouldn't be anything mechanically pushing it up, so I figure it is just air pressure. Maybe try replaceing you PCV valve while you are at it; they are like $5 and plug directly into the valve cover.
Old 03-08-2006, 11:20 PM
badassfocus1101 badassfocus1101 is offline
Banned
Send a message via ICQ to badassfocus1101 Send a message via AIM to badassfocus1101 Send a message via Yahoo to badassfocus1101
sounds to me like u got a crapper...
just my $.02
