Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-19-2006, 08:02 PM
violent31601's Avatar
violent31601 violent31601 is offline
Send a message via AIM to violent31601
need advise
my car has been acting really weird today, i put heat (yellow bottle) in my car today and filled the tank to half and its 20 degrees outside. Anyway to my problem, when i came to an intersection i put my clutch down to the floor and my car just died, i then started it back up and kept going. Next stoplight it almost did it again. What could this be?
Old 02-19-2006, 08:14 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
Re: need advise
mine does this because my coil is bad. that could be your problem
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 02-19-2006, 08:16 PM
Re: need advise
I believe it only does it when i push the clutch in
Old 02-19-2006, 08:19 PM
xavier3jr's Avatar
Re: need advise
same here. i know my coil is bad tho so I'm pretty sure thats why mine does it. when u push the clutch in the rpms drop instantly or are supposed to. and if your coil/wires/plugs are bad then they could just drop completely because the coil/spark plugs/wires aren't producing spark the way there supposed to. just my theory. if I'm wrong someone please correct me.
Old 02-19-2006, 08:26 PM
Re: need advise
you don't think this is a fuel/cold problem, i was also told today that putting the yellow bottled ISO Heat in a car is bad for it, versus the red kind
Old 02-19-2006, 08:32 PM
xavier3jr's Avatar
Re: need advise
still same problem ur not geting enuff spark to keep the gas ignited
Old 02-19-2006, 08:37 PM
Re: need advise
I will look into it, thank you very much
Old 02-19-2006, 08:39 PM
xavier3jr's Avatar
Re: need advise
NP or like you said that shit u put in there could have made the gas "less" flammable that could also cause the problem. try putting some gas treatment in it to see if it will clear that shit out.
Old 02-19-2006, 08:58 PM
E-Klips E-Klips is offline
Banned
Re: need advise
What octane gas are you using? Try filling your tank with 91-92oct and see if that helps... Usually one bottle is suppose to be used with a full tank of gas.
ned032002's Avatar
ned032002 ned032002 is offline
Re: need advise
Doesn't fuel treatment pull all the debris and water from your tank to the top of the tank then it is sucked through the fuel filter? My thoughts is that what if you clogged your fuel filter by doing this? I know 3 years ago when it was cold out I put that stuff in and i clogged my filter. Well I'm probably wrong but GL anyways.
Old 02-19-2006, 09:03 PM
xavier3jr's Avatar
Re: need advise
all i run is 93
Old 02-19-2006, 09:16 PM
Banned
Re: need advise
Why? It does nothing for your N/T. Cars that dont need it do not gain anything if you use it. Search it if you dont believe me... You're just waisting money.
Old 02-19-2006, 09:17 PM
xavier3jr's Avatar
Re: need advise
its only 15 more cents then 87 and its better for the injectors correct?
Old 02-19-2006, 09:22 PM
ned032002's Avatar
Re: need advise
Isn't it better for the injectors because it burns hotter and doesn't allow carbon to build up?
Old 02-19-2006, 10:07 PM
Re: need advise
All i use is 91, i have no clue where to get 93 at?
