Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 02-19-2006, 04:14 PM
LIL_MANDA LIL_MANDA is offline
Angry 95 Sonoma Issues
95 Sonoma, 4x, ext cab, auto. GMC IS NO HELP TO ME! Replaced every dang sensor, fixed cat, oil change, air filter, fuel filter, fuel pump, plugs, wires, cap/rotor, alternator, tried injector cleaners...losing my mind here. Truck will idle high or low, or just die when idling, surges when driving, tries to die when driving, really bad when on uphill, loses all power. Doesn't matter on RPM or speed, it does it's own thing. The only time it runs well is after disconnecting the battery...and that's only for 5 minutes. Please help.
Old 02-20-2006, 06:06 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: 95 Sonoma Issues
Have you checked fuel pressure? Have you pulled your upper plenum and checked for a leaking CPI/Nutkit (check for washing) (if you have CPI, if not, have you checked the spray pattern on your TBI and made sure the injectors aren't dripping?)
Have you tried pulling and cleaning your EGR and makeing sure the pintle is free and clear.
If the above has been done or you do it and shows fine I would look for a vac leak or clogged cat. But 1st, before you do anything more, get a farking pressure reading on your fuel!
