Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 02-19-2006, 02:27 PM
jpeck1221 jpeck1221 is offline
battary draw
I am looking for a draw on the battery of my 1992 dodge w250. With the neg bat cable unhooked should I read voltage between the neg post and the neg cable?
Old 02-19-2006, 04:53 PM
dadof4s dadof4s is offline
Send a message via AIM to dadof4s Send a message via Yahoo to dadof4s
Re: battary draw
You should only read voltage between the positive and the negative (post or cable), not the negative to another negative. You should, however, have continuity between the negative post and the negative cable.
Old 02-22-2006, 06:49 PM
1thunder 1thunder is offline
Re: battary draw
did you check the amperage draw between the negative post and the neg cable set you meter to 10 amp to start the if too little draw go to milliamp setting should not exceed .035 milliamp
