Go Back   Automotive Forums Car Chat > Ford > Contour
Old 02-19-2006, 01:45 PM
AL8 AL8 is offline
95 contours pleas help
95 contour v6 SE car start ok with cold engine, idle in range 2000 – 4000 rpm
as long is the car in gear runs ok, after it gets hot and I turn engine off. Car want start back up an till engine cools completely down.
Changed fuel pump and filter.
No ides what wrong with it, any help is appreciated thx.
Old 02-19-2006, 03:54 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: 95 contours pleas help
Iac
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 02-23-2006, 02:59 PM
MechanicDock MechanicDock is offline
yeah that's probably iac
Old 02-26-2006, 07:41 PM
AL8 AL8 is offline
Hey
I just changed IAC valve today, and did not help. I also change spark plugs and cables no change.
Old 02-26-2006, 08:10 PM
Originally Posted by AL8
Hey
Spark plugs and wires wouldnt cause a high idle. If they were bad, they would cause a really rough idle. Okay, the next thing I would try doing is cleaning the MAF. Theres a how-to on contour.org.
http://www.contour.org/mods/mods.php...o&displayid=36
"The CEG Nazi"
www.contour.org
Old 03-03-2006, 09:58 PM
drews2525 drews2525 is offline
The main problem that I have run into with the contour is that the wiring harness in the engine bay has a tendency to get a little to hot and cause more problems than need be. I just got done doing an engine swap in my 95 from the 2.0 to the 2.0 zetec. I am still working out the kinks but I have run into to many wiring problems. The big relay that is connected to the fan motor may have started to go bad on yours. This will cause it to get hot a lot quicker and maybe hesitate or not start. You might try to trouble shoot some of the main relays. If the wiring has gotten hot by the main fuse box in the engine compartment the relays may not work properly. I hope that this will give you some more insight on troubleshooting.
Old 03-08-2006, 09:01 AM
C. Cleve C. Cleve is offline
Hi, Sounds like a heat soak problem, Reflash the processor yet? Try it,
See Ya, Clay..
Old 03-09-2006, 05:31 PM
Actually what I did is do away with the harness all together. I ran my own togglew switch and wired it myself. So far so good. Other than that I have found that the zetec runs a good bit quicker than the stock 2.0 i now all I have to do is put a new clutch in it and prove to my boss that his 3.8 litre comaro is slower than the ford. Haha its the old ordeal of chevy versus ford. Gotta love it. Thanks for the insight though.
