Go Back   Automotive Forums Car Chat > Lincoln > Mark VIII
Old 02-19-2006, 01:32 PM
BlkMarkVIII BlkMarkVIII is offline
94 Mark VIII front end squeaking
The front end of my Mark VIII squeaks when i turn or go over some bumps and also over bumps there is like a clunk noise can someone tell me what is causing this
Old 02-20-2006, 01:51 PM
frankjc frankjc is offline
Re: 94 Mark VIII front end squeaking
Check the ball joints. Lowers tend to squeek when worn.
Old 02-20-2006, 09:26 PM
Crasen Crasen is offline
I am assuming the clunk noise is coming from the front??? Things you want to look closely at are upper and lowers ball joints, sway bar end links, strut lower mount bushing, Lower control arm to k member bushing, strut rod bushing, upper control arm to frame bushings, and tie rod ends.
Old 02-21-2006, 12:02 PM
Alright i'll have to check those things out, thanks for the help
Old 02-28-2006, 10:55 AM
also check the rack. they wear inside and make a clunk noise.
