Old 02-19-2006, 11:14 AM
tedv tedv is offline
97 GC Cruise Control Died, Clock spring?
The Cruise Control on my 97 GC worked one day and not the next. When I start the truck, the Cruse light flashes like normal. Is there some way to check to see if it is the switch or clockspring?
Thanks,
Ted
Old 02-19-2006, 12:11 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 97 GC Cruise Control Died, Clock spring?
Got any body trans or engine codes? Post back code no.
MT
MT
Old 02-19-2006, 12:49 PM
The only codes that I know how to read is the Ign sw On-Off 3 times. I then get a 55 by counting the flashes. How do I access the Trans and BCM codes?
Thanks,
Ted
BTW, if it matters, it has the 3.8L/4speed and is a Canadian vehical.
Thanks!
Old 02-19-2006, 03:08 PM
MT-2500's Avatar
AF - Advisor
A good commerical type engine scanner like a snapon MT-2500 red brick will scan engine,trans,body computers and do a test on the cruise switches an clock spring.
It takes a lot of guess work out of it and will pinpoint the problem.
Most good repair shops have a good scanner.
Good luck MT
MT
Old 02-19-2006, 03:14 PM
Being that the Clockspring is covered by a Lifetime recall and mine hasn't been done, should I just take it to the dealership?
Thanks,
Ted
Old 02-19-2006, 03:35 PM
MT-2500's Avatar
AF - Advisor
It would be a good idea to have them check it out.
May or not be the clock spring but they can check it and find out.
Good luck and let us know how it goes.
MT
MT
Old 02-21-2006, 07:53 PM
scott1447 scott1447 is offline
The clock spring also involves the air bag, that is why it is covered under warrenty. I took my 97 caravan in after the cruise failed and the air bag light cam on. I would take it in. It does not take long to fix.
Old 02-22-2006, 01:03 PM
coalminer coalminer is offline
Send a message via Yahoo to coalminer
One other item to check is the brake light switch, on my 95, when the cruise does not want to work, I reach up there with my foot and tap the switch, then it works.
Old 02-25-2006, 07:56 AM
HeadlessHorseman's Avatar
HeadlessHorseman HeadlessHorseman is offline
Send a message via AIM to HeadlessHorseman
There were MANY recalls for your '97... many of them because the problems are life threatening... like leaking fuel rails that could cause your van to explode under the hood and burn your Caravan to the ground, or a problem with the fuel filler neck that could cause an explosion when you're filling up your tank, thus, potentially, turning your local gas station into one huge fireball. There are other less dramatic issues (like the clockspring fix which, among other things, also resolves the problem of your airbags going offline). Better get those incomplete and/or unperformed (and FREE) recall fixes checked out and taken care of right away... go here with the last 8 numbers of your VIN to find out if you're good to go and good luck!...
http://www-5.dodge.com/webselfservic...m%28%27R%27%29
