Go Back   Automotive Forums Car Chat > GMC > Envoy
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 02-19-2006, 09:31 AM
adam c adam c is offline
02' envoy will not start
our 02, envoy will not start. turn the key and nothing happens. all the electonics in the car seem to be working. i have checked all related fuses etc. , also checked battery voltage. jumping is no help. any suggestions.
Old 02-19-2006, 09:46 AM
maxwedge maxwedge is offline
A990 racer
Re: 02' envoy will not start
Any am theft devices? does the security lite stay on? Try jumping the purple wire at the starter solenoid to the large lead on the solenoid.
Old 02-19-2006, 10:01 AM
the security lite is not on. the security system will arm using the remote and also disarms. i assume the key is on for suggestion of the jumper at the starter?
Old 02-19-2006, 03:50 PM
A990 racer
Yes.
Old 02-24-2006, 09:56 AM
AngeLT2508 AngeLT2508 is offline
Post Re: 02' envoy will not start
I have a '02 Envoy that has been into service 6-times for not starting. I could always jump it with no problem. Every 7-days the battery would die and it was back to service. Something on the truck was draining the battery. We were then told it was the original battery, and it was suggested we replace it. We also replaced the module for alarm system. That didn't solve the problem. We then, per Detroit's advice, disconnected everything after market. Even On-Star was disconnected. Finally after 3-months of the service department "not knowing what was wrong", they finally replaced a module for the rear door. So far, it has been starting each time (keeping my fingers crossed). Has anyone else had a similar problem?
Old 02-24-2006, 04:34 PM
A990 racer
What module, for the tailgate, need specifics to answer your question, what was wrong with the module relative to the battery dying?
Old 03-17-2006, 02:04 PM
simnel19 simnel19 is offline
I'm having a similar problem, my 02 Envoy dies after using the remote start a few times. I have replaced the battery and it still ends up dying. As a matter of fact, when I remote start it, the truck shuts itself off after a few seconds.
Any ideas or similar experiences???
Old 03-18-2006, 09:02 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Yes, that's a problem with bypassing the Passlock 2 system. It should start normal but stall like it's out of gas right? You'll have to have the bypass checked.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 03-20-2006, 10:02 AM
Not exactly, it does start up normally, but it shuts off if I open the door. When I try to remote start it again, it starts and then shuts off within 5 seconds. After a couple tries of this, the battery gets severly drained . I'll still have the passlock system checked though...Thanks a bunch
Old 03-20-2006, 10:58 AM
You've got something severly wrong. You gotta make sure all of the accessory and ignition wires hooked up. Failure to do so could really mess up things on your truck.
Pioneer 4900mp
Orion C63 Coax rear
Old 03-22-2006, 12:45 AM
Update:
Hey, it looks like I'm goin to get the whole remote start module removed. Before I do that, do you know if Envoy SLE's come with remote starts? If so, I can get it replaced under my warranty.
Thanx for your help, Ponchonutty
Old 03-22-2006, 06:13 AM
A990 racer
Update:
They did not.
Old 03-24-2006, 07:52 PM
Correct they didn't offer OEM remote start however Directed Electronics use to sell remote starters and alarms to GM dealers and labled them as GM/Delco. I would talk to your dealer's service center and see if they do them or who does them for them. Hopefully another shop actually does the installs for them and they'll tell you who they are. Otherwise it'll cost you a little more going through the dealer.
Pioneer 4900mp
Orion C63 Coax rear
Old 04-04-2006, 01:00 AM
Thanks Poncho, it seems like you know a lot about Envoys. I have a couple more questions about my truck, would it be okay for me to ask you?
Thanks Sim
Old 04-04-2006, 03:09 PM
Yes, I can try. I will tell you that my knowlege is purely electronics though.
Pioneer 4900mp
Orion C63 Coax rear
Closed Thread
