Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 02-19-2006, 03:00 AM
Gigantor-LS Gigantor-LS is offline
22re engine swap questions
I have 86 4x4 that has a bad frame. The engine runs great at 150k. I found a beautiful 88 4x2 with a blown motor so I was hoping to have someone swap the engine in.
I live in an apartment and will have to pay someone to swap the engine. How much does a job like that usually cost?
I know it might not be worth the time or the effort, but will the 4x4 drivetrain fit on the 4x2 frame? Are they the same frame? I know it might be a bit pricey to have someone do that but with a imaculate frame and body, it might be worth it.
Thanks for any advice.
Old 02-20-2006, 02:31 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: 22re engine swap questions
Since both trucks have a 22RE, swapping should be fairly painless. A good shop should be able to do it in 2 days, 3 tops. Figure ~$70/hr for labor and do the math to get a ballpark idea.
Converting from 2WD to 4WD is a lot more work, and if I was going to spend the $$ I'd ditch the IFS for a solid front axle.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 02-20-2006, 07:33 PM
Thanks for the info fourwd1.
Old 02-26-2006, 09:19 AM
SidneyCanada SidneyCanada is offline
You did not specify where you are located.Find a friend,relative,neighbour,co-worker or local off-roaders where will replace your engine for about $300 max that's taking the both engines out and swapping in the good one.Also call your local community colleges/vocational schools and they might do it for free.
Sidney® ™
Repairs tv's,vcr's,home/car audio out of my home
E-mail:[email protected]
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 247 000 KM
http://groups.google.com/group/hfx.f...4c696fbf04837f
http://www.iwaynet.net/~nesda/May02/May18.html
http://www.iwaynet.net/~nesda/SonyAudMod.html
http://www.newark.com/product-detail...ge/32-9495.jpg
http://www.tipsmaster.ca/hottips-1.HTM
http://www.tipsmaster.ca/1011-TV32C50-007.jpg
http://www.iwaynet.net/~nesda/June03/June0315.html
http://www.iwaynet.net/~nesda/Apr03/Apr033.html
