Old 02-18-2006, 10:42 PM
CWW17 CWW17 is offline
Send a message via AIM to CWW17
Service Engine Soon Light!!!
I just put on the SLP smooth bellow, MAF Sensor, and Air Lid. I had quite a bit of trouble getting the lid to fit properly and also there is a plug like thing that was connected to the old setup and no longer has a place to put it in... then after i got done i went for a test drive and the service engine soon light came on. so i shut the car off and restarted and the light is still on. the car has no leaks or anything, and runs as good as ever... any ideas???
Old 02-18-2006, 11:29 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: Service Engine Soon Light!!!
First off....put the stock MAF back on and return the 85mm one if you can.
Better for your car.
That is probably the code. Bet it leaned you out enough to make the computer throw the code.
Unless a sensor wasn't re-connected by accident.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 02-19-2006, 03:33 AM
well i cant return it... but what can i do to get rid of the light?? also, what is the smaller plug that isnt being used anymore? and did anyone else have problems with the lid fitting...? it just didnt seem to want to fit right...
Old 02-19-2006, 07:44 AM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
I'm not too keen on the 98-02 intake systems. So someone correct me if I'm wrong, but the "plug like thing" he's referring to, isn't that the Air Temperature Sensor? My friends 2000 T/A has one in his intake lid, and I believe that's what he said it was. So if you bought a new air lid, and it didn't have the sensor harness already in it, then that sounds like that's your problem? Seeing as in how you wouldn't be able to connect the cord back to the sensor. I'd call SLP and see what's up with that crap.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 02-19-2006, 08:38 AM
Mr. Luos's Avatar
Firebird Guy
On to something with that.
It needs removed from the stock piece and installed on the new lid.
Can you get pics? That should tell me right away.
Stock'ish'
Old 02-19-2006, 08:50 AM
blindeyed's Avatar
eBay aDdict™
Yeah, is there a small hole anywhere on the new lid you bought? If so, then I'd assume that's where you're supposed to take the air temp sensor out of your old lid and put it in that one. That way you can then reconnect the sensor.
- Jason
Old 02-19-2006, 11:59 AM
yes thats exactly what it was... thanks alot guys! however, how do i get the SES light to go away now??? also did anyone else have problems with the lid fitment though? mine is an extremely tight fit and it just does seem like its on there correctly... seems like it could be on there better if i trimmed down the bellow maybe?
Old 02-19-2006, 01:10 PM
Mr. Luos's Avatar
Firebird Guy
Mine is kinda a custom job.
Yes...I had to cut down the Fernco piece a couple times to get it to fit. Still a VERY tight fit. Probably too tight.
Stock'ish'
Old 02-19-2006, 01:15 PM
well everything is hooked up properly now... i just need to know how to get rid of the Service Engine Soon light
Old 02-19-2006, 01:17 PM
Mr. Luos's Avatar
Firebird Guy
You can either wait...or try this.
The LS1 takes a little more than just disconnecting the battery to reset the ECM.
If you want, I can get you the instructions.
Or, you can drive to AutoZone, have them read the codes, and clear them. This would be a good idea just to make sure it was just that one sensor.
Stock'ish'
97cavalier's Avatar
97cavalier 97cavalier is offline
plug the ob2 in and earase it.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 02-19-2006, 04:16 PM
thank you all very much, all fixed!
