Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 02-18-2006, 08:14 PM
brattzzzzz brattzzzzz is offline
Dodge ram 3500 will not go into Neutral or Reverse
hi i dont know why but it wont go into nuetral or reverse
does any1 have any suggestions?
i just put new friction clutches in the transmission!
Old 02-18-2006, 09:47 PM
troy1 troy1 is offline
AF -Advisor
Re: Dodge ram 3500 will not go into Neutral or Reverse
Did you replace them your self? Does it have all the forward speeds? also what does it do when you put it in "N" and "R" move forward?
Old 02-18-2006, 11:33 PM
in R and Neutral it does the same thing it doesnt move but its not in neutral. in all other D 2 1 they drive forward correctly
Old 02-19-2006, 09:45 AM
AF -Advisor
So in "R" it does not move. In "N" it does not move either? So how do you know that "N" is not "N". As for "R" check the adjustment of the rear band also make sure the band strut is not laying in the pan. Also who replaced the friction If a shop did take it back.
Old 02-20-2006, 03:58 PM
i put the friction plates in
i did not touch the rear band i will double check it today
in N and R it just doesnt move and its not in Neutral
it was that way before i put the friction plates in though
when i got in the tranny the friction plates were completely worn out COMPLTETLY
Old 02-20-2006, 04:37 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
I thought it wasn't supposed to move in neutral?
My Mopars
Old 02-20-2006, 05:29 PM
dadof4s dadof4s is offline
Send a message via AIM to dadof4s Send a message via Yahoo to dadof4s
If it is not moving, how can you tell it is not in neutral?
Old 02-20-2006, 07:13 PM
well in neutral it is supposed to roll correct
its not rolling we tryed to roll it
Old 02-20-2006, 07:20 PM
i had to take the driveshaft off to move it to a different location where i could work on it today also because i cant get it into neutral
Old 02-23-2006, 09:49 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
So the problem existed BEFORE you did all the work...sounds like you have a previously existing transmission problem, my friend.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 02-23-2006, 08:55 PM
hahaha
probably should get a different transmission ehhh
i didnt tighten the rear band though
Old 02-23-2006, 09:27 PM
AF -Advisor
Did you happen to look at the planet right under the forward and direct clutches? Some times that planet gets all messed up and it binds up. what kinda of junk was in the pan when you pulled it for the new clutches.
Troy
Old 02-23-2006, 09:44 PM
the oil was horrible there was alot of junk in the pan i believe i saw some metal shavings also but i know the friction plates were so bad they grinded up some of the steels cuz there was no friction at all left on them. the steels were also bent a little
i did not change out the steels i just put them back on. thats probably my problem right. i dont see why reverse doesnt work but i could see why Neutral doesnt work if the friction plate steels are a bit bent
Old 02-23-2006, 10:03 PM
tony36 tony36 is offline
Send a message via MSN to tony36
Did you reprogram the trans? When you r&r those there is a specific series you have to go through to reprogram them
Old 02-23-2006, 10:08 PM
no i did not reprogram them i dont even know this was possible and i dont have the tools to reprogram the trans
should i have it reprogrammed?
