Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 02-18-2006, 06:32 PM
Ramz Ramz is offline
96 Jetta Gls Electric Problem
I am a new vw jetta owner and noticed that whenever i turn my ignition off, the alarm automatically activates itself. As soon as a door is opened the alarm goes off. I also noticed that whenever i activated the defroster for the rear view window, the interior lights go dim and the driver side window will not go down. Advice and help with this problem will be greatly appreciated, Thank you.
Old 03-13-2006, 12:42 AM
nessa8223 nessa8223 is offline
Send a message via AIM to nessa8223 Send a message via MSN to nessa8223 Send a message via Yahoo to nessa8223
Re: 96 Jetta Gls Electric Problem
We just had a similar issue with our 1994 Jetta GLS. We had weird stuff happening and through taking stuff apart and checking wires, we found out that the wires in the left rear door were severed, probably because of the poor design of when you open and close the rear door, the way the wires are set, the door severed them. We just ended up splicing the wires and using butt connectors to fix the problem ourselves rather than taking it to a shop and paying top dollar for them to fix it. I hope this helps. Also, check the wiring harness. You might find the problem there as well, and sadly people rarely check there.
