Power Problems!!!
ok, for about 4 hours the parking lights were left on....Now when the key is turned the gauges jump around (all) and as you go to on, there is a constant clicking noise...
Okay, so you would think low batt. well i did, as I was jumping the + terminal on my car when nuts (sparks like crazy)....I did this twice, dont know if anythings wrong or what....it just snowed |
Re: Power Problems!!!
Year?
Sure the jumper cables weren't accidentally backwards? Sounds like it is grounding out.
1999 Pontiac Trans Am WS.6 #1747 Stock'ish' |
its a 2000, i dont know it just got done sliding of into the median, but its a fairly flat median at that....so much for woman drivers |
Clicking....sounds like the starter.
Might have a ground lose/off from the starter.
When you were jumping it, did you put make sure you had the + and - cables on the right terminal? |
I don't know how your medians are there but maybe like Mr. luos said a wire came off or loosened up off the starter when the car went sliding
F-Bodies Forever Member #2 |
well, aparently you cannot jump a car with side and top mounts. If the sides are used the tops CANNOT be used....learned that by experience, Car runs GREAT now
Thats weird. I got the side/top mounts on my battery. Everything is hooked up to the side mounts and I was able to jump my car off the top. What it is is maybe there was a tight fitting cover on one of your mounts.
