Old 02-18-2006, 03:58 PM
JJ122 JJ122 is offline
Snapped strut
I bent the lower metal plate that the strut connects to on the rear driver's side, does anyone know how to fix it? and how to put in a new strut?
I didn't see a pot-hole(sink-hole's more like it ) till it was to late, cost me a tire, that plate, and a strut (broke it in half).
I have a 94 camaro V6.
any help would be appreciated.
Old 02-18-2006, 05:03 PM
x_skaven_x x_skaven_x is offline
Send a message via MSN to x_skaven_x Send a message via Yahoo to x_skaven_x
Re: Snapped strut
ouch...that really sucks i have no idea how to fix it but ouch
1992 Grand Prix - Blown Motor
1990 Aerostar - Blown Motor
1999 Venture - Blown Motor/Blown Tranny
Next on the List....
Old 02-18-2006, 06:21 PM
malletslinger's Avatar
malletslinger malletslinger is offline
Re: Snapped strut
Might be time to take a trip to a pick-a-part Good luck
Old 02-18-2006, 10:31 PM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
Re: Snapped strut
Your talking about the lower mount that the spring seats into right??? If so, you cant fix that. you need a new strut.
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
Old 02-20-2006, 10:19 AM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
Re: Snapped strut
just try to bend it back in place... i'm assuming you're talking about the place that the shock mounts to the rear axle... that doesn't come off, you'll either have to bend it, cut it off and weld on a new one, or get a new rear axle... replacing the rear shock is simple enough... lean the back seats forward, lift up the carpet, you'll see two places right behind the seats that have a yellow foam covering on top of them, take off that foam, put an alan key in the center of the nut, and turn the nut with a wrench to get it off... then just put the new one in there and tighten it
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 02-22-2006, 09:24 PM
Re: Snapped strut
It doesn't matter anymore I dont have a torch so I took it to my mech. and he is going to bend it back and put in a new shock. and how do you un-bolt the shock from the lower mount?
Old 02-22-2006, 11:40 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Re: Snapped strut
With a ratchet and socket???
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 02-23-2006, 06:22 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Snapped strut
Since when did 4th gen's use struts?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
