Old 02-18-2006, 02:23 PM
zx2guy zx2guy is offline
ethonol 85?
anybody hear anything on this corn ethonol that chevy is starting (well has had for a few months now) to push? that think green go yellow or what ever it is. good idea to be capitalized on or no?
ford guy.... i know, and im sorry.
Old 02-18-2006, 04:06 PM
Andydg Andydg is offline
Re: ethonol 85?
So far I like it...it's cheaper than gasoline but you get worse mileage but it's cheap enough that you come out ahead.
Old 02-18-2006, 06:04 PM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
Re: ethonol 85?
^it's not cheap enough yet. it currently costs as much as gasoline and you have to refill more often cuz it burns faster. however you do get more power from it since it's a higher octane. as there becomes more of a market for for e85 the price will come down.
check out either www.livegreengoyellow.com or www.e85fuel.com
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 02-18-2006, 06:25 PM
FlippiN.af's Avatar
FlippiN.af FlippiN.af is offline
Send a message via AIM to FlippiN.af Send a message via MSN to FlippiN.af Send a message via Yahoo to FlippiN.af
Re: ethonol 85?
Is this ethanol85 more available than gasoline or fossil fuel?
http://mks-7zdesigns.com
Old 02-18-2006, 07:31 PM
abaird abaird is offline
Re: ethonol 85?
Here in the midwest it is quite a bit cheaper to buy E85. If you can run it that is. I think it is a good thing because it is made from corn which is a renewable fuel. I don't know what the octane is, but higher octane doesn't give you more power. Basically, the higher the octane, the less likely you are to have a knock(so don't waste money on the high priced fuel, 87 octane is all you need). High compression engines need to have high octane to prevent detonation. The truth is that ethanol produces less energy than gasoline so that is where the crappy fuel mileage comes from.
2009 Silverado 1500
2002 Camaro Z28(rebuilder)
2005 Yamaha GP1300R
Old 02-19-2006, 10:13 AM
Re: ethonol 85?
sooo this is kinda like the switch from leaded to unleaded back in the early 70's? i mean its gas, but different.
Old 02-19-2006, 10:27 AM
Steel's Avatar
Steel Steel is offline
Re: ethonol 85?
Biodiesel and alcohol is where its at. That and you can run alcohol at like 3:1 a/f ratio and get some power iirc. Then again, at that rate, you'll be getting a whole 3 miles to a gallon. i think stoich for alcohol is 6:1
BP2K2Max's Avatar
Re: ethonol 85?
This is quoted from GM's Live Green Go Yellow web page in the FAQ section.
"using E85 ethanol can help improve your vehicles performance, how? E85 ethanol has a higher octane rating than gasoline, which allows for more hp and torque."
BP's Rides;
Old 02-19-2006, 10:37 AM
-Jayson-'s Avatar
-Jayson- -Jayson- is offline
Re: ethonol 85?
thats not really right, just stupid marketing. Octane alone does not make HP. If you put 108 Octane Race gas in your car that requires 87 octane, nothing special is gonna happen. You wont see anymore HP. The HP increase comes from the increased compression that is allowed because of the higher octane. The more you compress the air/fuel mixture the more powerful the combustion is. Race cars compress the airfuel ratio so much that it turns into a near solid state.
2009 Ninja 650 R
stock for now...
SouthEast Ecotec Enthusiast
Old 02-19-2006, 10:55 AM
BP2K2Max's Avatar
Re: ethonol 85?
damn, of all people to make a mistake like that you'd figure GM would know better. regardless the real benefits are that it helps diminish our dependence on foreign oil suppliers, it burns cleaner and it helps support our agriclture industry.
BP's Rides;
Old 02-19-2006, 08:55 PM
2strokebloke's Avatar
2strokebloke 2strokebloke is offline
In Stereo where available
Re: ethonol 85?
E-85 has been consistently cheaper than gas at the stations around here (usually about 10 cents cheaper per gallon). E-85 has also been around for pretty long time, it's definately not new.
Support America's dependence on foreign oil - drive an SUV!
"At Ford, job number one is quality. Job number two is making your car explode." - Norm McDonald.
If you find my signature offensive - feel free to get a sense of humor.
Old 02-20-2006, 09:35 AM
speediva's Avatar
speediva speediva is offline
Send a message via AIM to speediva Send a message via Yahoo to speediva
Re: ethonol 85?
Yeah, but alcohol in certain quantities (ie. at Sunoco with their ethanol as an additive) makes my Subaru knock... NOT cool.
Like a boy - but BETTER!
2005 Subaru Forester 2.5X
1997 Honda Civic EX Coupe
Inform yourself:
AF User Guidelines
Old 02-20-2006, 09:43 AM
Igovert500's Avatar
blue + red light magnet
Re: ethonol 85?
http://www.3si.org/forum/showthread.php?t=284068
We were just discussing this, as it relates to boosted cars, on another forum. Some good points and links if you are interested.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-20-2006, 09:53 AM
G-man422's Avatar
G-man422 G-man422 is offline
Re: ethonol 85?
I think its a good idea. i also think that it will eventually be used in every car.
Old 02-20-2006, 11:54 AM
Jet-Lee's Avatar
Jet-Lee Jet-Lee is offline
Banned
Send a message via AIM to Jet-Lee Send a message via Yahoo to Jet-Lee
Re: ethonol 85?
A higher octane rating means the fuel burns slower. 93 fuel burns slower and more controlled than 87. But because the 87 burns more fierce and faster, it's a stronger explosion inside th engine resulting in more power. The higher octane you go, without upping compression, the lower your hp/tq gets.
That's piss poor advertising on GM's part.
