Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 02-18-2006, 01:59 PM
jrod87 jrod87 is offline
problem with 90 deville
I have aproblem with my 90 deville, it has a missfire and lacks power. I've changed plugs wires etc, changed fuel filter too, not getting any codes. Can anyone help
Old 02-18-2006, 02:58 PM
maxwedge maxwedge is offline
A990 racer
Re: problem with 90 deville
Misfire when, at idle, need more info here?
Old 02-18-2006, 06:50 PM
it misses at idle and clears at higher speeds. it takes a while to get to speed. The car hesitates when taking off. I was driving up a hill and was losing speed with the pedal all the way to the floor and when I first got the car I took the hill like nothing.
Old 02-18-2006, 07:04 PM
A990 racer
Try and isolate which cylinder has the misfire, if this is port injection disconnect one injector at a time and see if you can feel the cylinder that does not change the idle roughness, then check that plug and or wire. If all ok could be a bad injector, but additional diagnosis must be done.
Old 02-18-2006, 07:13 PM
Thanks for the help will try this
