Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 02-18-2006, 01:40 PM
alisonmarie08 alisonmarie08 is offline
Unhappy girl whose car won't start
Ok, Let me start by saying I know nothing about cars. But here goes, I have a 2000 cavalier that will start. It worked fine last night, but I went to leave this morning and it's snowing out and it just would not start. The dome lights came on when I opened the door and even the cdplayer/radio works. All inside lights come on, just not as bright. However, when I went to turn it all the way to start it up, it's like the car went dead. Nothing worked at all when it was turned all the way. There was a click then nothing, just dead. Does anybody have any suggestions. I am trying to deal with this without calling my dad. Any ideas? I would appreciate anything. If it were the battery why would I be able to listen to the radio? Help me!!
Old 02-18-2006, 03:03 PM
maxwedge maxwedge is offline
A990 racer
Re: girl whose car won't start
Try tightening or moving the battery cables, may be a bad/loose connection.
Old 02-18-2006, 07:02 PM
adamhamrick's Avatar
adamhamrick adamhamrick is offline
if tightening the cables don't work then you probably have a bad battery. You can listen to your radio and your lights will even work with a bad battery because the amp draw is so low. Like the guy said.......check your cables and if that don't work, get the battery tested.
Old 02-21-2006, 08:49 AM
jveik jveik is offline
yeah it takes a lot more juice to "turn over" your engine than to run the radio... that little click you hear when you turn the key to start or "all the way" is just the starter kicking in, but it isnt getting enough power to actually turn over the engine. its just like if you had a 10 speed bike in its number 10 gear and were facing up a hill and tried to start pedaling. you can push all you want, but theres not enough power to make the pedals start spinning... almost just like that
Old 02-27-2006, 01:49 AM
inatalonIXLR8 inatalonIXLR8 is offline
One way to find out if it's battery related is to put a set of jumper cables on it and see if that helps.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 10-09-2006, 10:26 AM
Rebel Racing 3's Avatar
Rebel Racing 3 Rebel Racing 3 is offline
It could also be the starter, we had a car in the shop the other day that the customer brought in after he had already changed out the bat. and it turned out that his starter was drawing so much volts that it would kill even a new bat
Old 10-09-2006, 10:40 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
I would suggest it's either battery or corrosion. What you describe (Allison) is a classic case of corrosion, but it could also be a battery post internal failure (the post, or terminal, breaks inside the battery) as sometimes this happens with side-terminal batteries such as what you find in GM cars.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 10-09-2006, 03:01 PM
A990 racer
For what it is worth this, thread was 8 months old.
