Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-17-2006, 11:32 PM
bighops2000 bighops2000 is offline
Send a message via AIM to bighops2000 Send a message via Yahoo to bighops2000
Question Engine Swap Question
I have read on the internet and heard from mechanics, that it is possible to make this swap....
I have a 95 3.2L V6 Rodeo (2wd) and I want to put a different engine in it.... Not an isuzu engine (notorious for the tick) I want to use the chevy vortec engine. I heard that this engine is in some of the troopers andit can fit rigthinto the rodeo. If anyone know for sure this can be done let me know. Alsoif you know of any other swap that are possible and, most impotantly, worth doing. I am just not sure of the fact that the vortec is a much newer engine and may not be compatiblewith the older (95) rodeo.
Old 02-18-2006, 07:35 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Engine Swap Question
anything is possible with enough time and money. If you are buying a chevy engine you will also need a wireharness, ecu, tranny, transfer case, rearend, and new engine mounts too.
Probably cost 5-7k for all the parts used installed (not very cost effective)
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 02-18-2006, 08:45 AM
rodeo02 rodeo02 is offline
No, I dunno of a vortec that will bolt to the trans (4L30E or 5spd). The GM RWD 2.8/3.1/3.4 will, plus the northstar V8 will. No confirmation on this, but I don't see why the GM 3.5L V6 "shortstar" wouldn't either, as it's the same as the northstar, minus two cylinders. The "shortstar" was used for like 2 or 3 years in olds aleros and auroras. Even these bolt-up engines require mods for the starter, cooling, exhaust, wiring, etc.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
