Old 02-17-2006, 08:49 PM
kimbergross kimbergross is offline
1999 key less remote
hi i need to know how to program a new keyless remote for my 1999 z24 cavalier thank for any help kimber
Old 02-20-2006, 10:10 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: 1999 key less remote
All Remote Keyless Entry Modules may be programmed to receive four different
transmitters which all may be used to operate the remote control lock system on the
vehicle.
Also, severalvehicles, each with the same system may all be programmed to operate from the same transmitter or four different transmitters.
Step 1. Turn ignition off
Step 2. Ground the program pin.(within one second, Lock, Unlock and Trunk will cycle to indicate module ready for programming.)**the program pin is the two wire connector plugged into the RKE reciever in the trunk of the vehicle at the Left Wheelhouse. Leave the main harness plugged in but unhook the two wire connector and ground the pins.**
Step 3. Press and hold the LOCK and UNLOCK buttons until:
Lock, Unlock, Trunk, and Horn cycles to indicate the transmitter has successfully been programmed.
(This takes no more then 12 seconds)
Step 4. Repeat step 3 for the remaining number of transmitters
Step 5. Remove the ground from the program pin.
Step 6. Verify proper operation of the transmitters.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 03-28-2006, 12:53 PM
delongboy delongboy is offline
will this work with a 2002 z24?
Old 03-28-2006, 02:51 PM
iam not sure try it what do you have to lose kimber
Old 03-28-2006, 02:58 PM
I would hate to blow the reciever by grounding something that shouldn't be.
Old 03-28-2006, 04:00 PM
yes i would not like that my self may be some one out there knows kimber
Old 03-29-2006, 06:31 PM
Onblsht's Avatar
Authorized Vendor
It will NOT work on a 2002...those require dealer programming.
Old 03-29-2006, 07:34 PM
chris thank for info
