Old 02-17-2006, 07:39 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Stop Leak Suggestions?
Can anyone recommend a good product to use to try to plug a radiator leak?
Old 02-17-2006, 09:30 PM
gmtechnician gmtechnician is offline
Re: Stop Leak Suggestions?
I don't recommend any stop leak. Repair the rad properly and you won't be sorry.
Old 02-17-2006, 09:49 PM
mechhound mechhound is offline
BARS LEAKS
Old 02-18-2006, 12:33 AM
Davescort97 Davescort97 is offline
Escort guy
ALUMASEAL or JB WELD if you can get to it on the outside. Hey moose! you can get a whole new radiator on ebay for $24.99 plus $32.99 shipping. Item #8038923233 by the Radiator Connection.
Old 03-04-2006, 01:16 AM
phreaq's Avatar
phreaq phreaq is offline
Barsleak, Alumiseal, anything you put in your radiator to clog a "leak" will CLOG. Plain and simple, your pouring something into your coolant that clogs your system. You will not only end up cloging a leak, but the radiator, the water pump, the thermostat, and any other narrow passages in the block and head. You may was well pour sand in you radiator.
Old 03-05-2006, 04:37 PM
I ended up using the JB Weld option. The leak was tough to get to... in fact it was tough to locate... but once I did I was able to goop enough JB Weld in there to plug it up and it worked like a charm.
Old 03-06-2006, 11:45 AM
Escort guy
Yeah, JB Weld will fix almost anything. It is actually a steel impregnated epoxy with a hardener that cures in about 16 hours. It is good stuff.
