Old 02-17-2006, 06:41 PM
camaromaniac camaromaniac is offline
Arrow another overheating problem
OK, last year, I had the thermstat replaced and intake manifold gasket replaced. the radiator is full of coolant. but sometimes after driving a while, i hear a bubbling noise and lift the hood, and the coolant is boiling up into the reservoir. my gauge says overheating, but there is plenty of coolant. Help?
Originally Posted by Rally Sport 92
Dont get me wrong though i'd love a Lt1 in my Camaro even if it had Richard Simmons strapped onto my hood naked..
Old 02-17-2006, 07:58 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: another overheating problem
your thermostat might be stuck or getting stuck.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 02-17-2006, 08:05 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
is the fan working?
Old 02-17-2006, 08:08 PM
Originally Posted by Genopsyde
is the fan working?
yes
Old 02-17-2006, 08:21 PM
97cavalier's Avatar
ya, pull the termostat and see if it stuck closed or barily open.
Old 02-17-2006, 08:31 PM
gmtechnician gmtechnician is offline
If you drive over 30mph and it does not over heat it is not a fan problem.
It is probably a stuck thermostat. Flush the cooling system if replacing
the thermostat. Possible debris in cooling system sticking thermostat.
It may even be the start of a head gasket problem.
Old 02-18-2006, 12:38 PM
AFI 05 AFI 05 is offline
Send a message via AIM to AFI 05
do you have that spoiler under the car that diverts air into the engine compartment when you are in motion?
1990 IROC-Z 5.7 TPI (1 out of 4,213 IROC's made in 1990) Only mod is magnaflow 3" cat back and K&N filters... im broke.
Old 02-18-2006, 01:03 PM
malletslinger's Avatar
malletslinger malletslinger is offline
He is talking about the black plastic air dam that mounts right under the radiator.
When I first got my camaro, this was missing and the result was overheating... Make shure yours is there
Old 02-19-2006, 12:18 PM
well, i went and looked under my car, and saw that the air dam is missing. i'm gonna get another one, but where exactly does it go? does it mount in front of and right under the radiator?
Old 02-19-2006, 01:21 PM
Yes.
There is one here that ends in about 3+1/2 hours
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
But you could probably get a better deal at a salvage yard.
Old 02-19-2006, 01:45 PM
i was just gonna buy one new from hawks third gen, they're only $25
Old 02-19-2006, 01:48 PM
Thats even better
Old 02-19-2006, 03:13 PM
there should be some mounting holes under there if your unsure of where to put it. yeah and THEN see if it overheats..
Old 02-20-2006, 10:29 AM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
the fact that the water is overheating and boiling up... tells me that you have a pressure leak of some kind in the system, because w/out pressure the water won't stay water, it will start to evaporate... i don't think its an air dam... i mean that might make it run kinda hot, but it couldn't make the water boil, because if the system is kept under pressure, the water can't boil. i think you have a pressure leak somewhere
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 02-20-2006, 11:03 AM
how could i find the leak?
