Old 02-17-2006, 05:29 PM
tcluck tcluck is offline
99 windstar no heat in front...help!
My 99 windstar has seemed to have issues every month since it's been paid off! Isn't that how it goes....anyway,
Just recently the heat suddenly stopped working. The fan is blowing and the temp controls seem to function correctly. There is no heat comming from the front and some IS comming from the back.
what could the problem be? Blend door, actuator, motor, evaporator core? any ideas?
Any help would be appreciated. Thanks so much!
Old 02-17-2006, 08:38 PM
dougand3 dougand3 is offline
Re: 99 windstar no heat in front...help!
I'd try back flushing the front heater core. There may be enough film in it to prevent heat transfer even tho there is coolant flow. Stick a garden hose in and blow opposite the normal flow. Don't remember which hose, tho....you may be able to tell by grabbing each one when at op temp and the hotter one is IN. You want the garden hose shooting in the OUT. I've also soaked a core in CLR with a little water for 10 minutes, then run 10 gallons of water thru it.
83 MB 300SD - 305k miles
93 Escort 1.9L LX Wagon - 220k miles
95 Isuzu 2.3L P'up - 230k miles
Old 02-17-2006, 08:43 PM
kurtr kurtr is offline
This might seem obvious, but make sure you have sufficient coolant in the radiator and resevoir. When my '98 was loosing coolant, I could always tell when it was time for a refill because the heat would barely work.
Old 02-18-2006, 07:11 AM
garync1 garync1 is offline
When you slide the temp controls back and forth do you here a clunking sound or thumping sound comming from the dash. If so it might be your blend door, not a hard fix. Does your temp guage show an increase to operating temp. If it keeps showing cold could be the thermostat.But if you are getting heat to the back I would check the blend door motor..I have a 2001 and had to replace mine .If thats your problem I can share some info on replacing it.
Old 02-18-2006, 09:58 AM
I do have an initial klunking sound when I turn the heat/air on, but it's always done that - kinda sounds like the compressor or something clicking on.
Anyway, I am getting heat in the back....
I took this into a shop for a cheap guestimate on what this might be. They didn't have it in long enough to tear up the dash and look to see if it was the blend door. All that was said is.... no heat, heater blend door in operable. Their solution was to purchase an evaporator core (entire main unit) - $440. This is supposedly the way ford manufacturers the thing. According to them and the dealer, I cannot just purchase the blend door. I just don't know how to determine if it's a BROKEN blend door, failed blend door actuator or motor. Any suggestions? -
Also, I'd appreciate any info on how to fix this.
Thanks so much for your knowledge!
Old 02-18-2006, 10:12 AM
thscott thscott is offline
I had this exact same problem on my 99 Windstar a couple months ago.
Searching this forum you'll find this to be a very common problem - either caused by a failure of the blend door actuator or the blend door itself.
The blend door actuator is a $40 part located behind the radio. It is relatively easy to remove and replace - 3 screws and a wire harness. It is a white plastic part about the size of a deck of cards. It has a 3 inch shaft which goes into a small opening on the heater plenum unit to turn the blend door itself. Search this forum and you''l find step-bystep instructions, photos, etc...
For me, the blend door itself had failed. This required the entire plenum heater unit to be replaced which was a very expensive repair - the dash has to be taken apart. 10 + hours of labor; $2,000 repair bill!! Very painful.
Check your fuses and relays first. Then pull the radio and observe the back of the blend door actuator shaft to see if it rotates.
If the actuator motor seems to be working, then I'm afraid you may have a broken blend door which cannot not easily be repaired or replaced without replacing the entire unit.
Good luck.
Old 02-18-2006, 06:00 PM
wiswind wiswind is offline
I would do a search on this forum on "blend" and look the posts over.
I remember seeing some pictures that showed the issues in detail.
Thing is, the front heat is separate from the rear heat.
Also, the blend door and controls run off of vaccum.
It would be worth a try to look up under the dash to see if a vaccum line has fallen off. You will see some silver "bulbs" with vaccum lines going to them.
Most likely this is not the problem as the shop SHOULD have found something that simple and corrected it.
The source of the vaccum for the heater controls is the back side of the upper intake manifold. Then there is a box - like unit on the passenger side, near the fire wall....on the side of the inner fender, that is a "holding box" for vaccum. If you are hearing something when you move the heater controls, then you most likely have vaccum....and the problem is with the blend door as listed.
Of course, as one post suggests, verify that you have the correct amound of coolant in the engine AND overflow bottle. You should be able to feel coolant in the upper radiator hose when you squeeze it.
It IS possible to have a full overflow bottle, and be low on coolant in the engine, if the seal on the radiator cap is not present. A very small amount of grit inside the neck of the radiator, where the cap seals, can cause it to not seal, and can be bad enough to let air in at that point, taking the overflow bottle out of the loop.
Old 02-18-2006, 06:09 PM
phordguy phordguy is offline
Umm, the blend door for the front heat is controlled by an electrical actuator.
Here's a pic of the heater box where you can see the blend door.
Old 02-18-2006, 09:19 PM
This is an awesome forum!!! Before I posted this problem, I didn't know too much about the blend door, actuator, etc.....
I think I've gathered quite a bit of info from all of you and from searching "blend" & blend door actuator on this forum!
Hopefully it has sunk in enough for a FIX to be just around the corner! I'm freezing in this windstar!
I'll post again for more help with this I'm sure....
Tina
Old 02-18-2006, 09:22 PM
phordguy,
I have a dumb question for you. I have seen this actuator/motor in other posts, but I'm not sure what I'm looking at on the heater box. Which part is the blend door? Is it the thing in the "box" on the left with the hoses, or the small "box" on the right of the heater box pic?
Thanks!
Old 02-18-2006, 11:17 PM
Here's a pic of the blend door which is in the pic on the heater box in the center. The silver tubing is for the A/C evaporator and is just to the left of the blend door. The door is hinged on the right side of the square hole in middle of the heater box. In the pic in this post you can see the square with the one rounded side where the shaft of the electric actuator fits into. This rounded square is one of the two points that makes up the hinge. The rounded square is on the side of the heater box facing the radio, the side of the hinge on the blend door that faces the firewall is just a point. Both pieces of the hinge protrude each through their own holes in the heaterbox to allow the blend door to go up or down. When the blend door is air is forced through the heater core, the velocity of air will hold it up until the van is turned off and the airflow stops, then no heat again. The default position if the actuator fails or if the blend door hinge breaks is to go down thus preventing any air through the heater core and thus cold air though the vents.
The pic below is of the door but its upside down from the way its installed in the view of the heater box.
This pic below and the two above are from 12ounce. The one below shows the reinforced section on a repaired '99 Windstar blend door, aka the "12ounce" method.
Old 02-20-2006, 08:48 AM
I need to correct an error I made in my earlier reply when I stated the length of the blend door actuator shaft is 3 inches long.
Upon inspection of the part, the shaft is just a little over an inch long.
As another post mentioned, it's the D-shaped female recepticle (socket) that this shaft fits into on the blend door itself that is prone to failure.
Old 11-04-2007, 12:11 PM
radchogers radchogers is offline
Smile Re: 99 windstar no heat in front...help!
Thanks to all of you who posted replies to this forum! I have a 99 windstar and the information in this forum was what I absolutly needed to fix the problem! It worked! The actuator was a $45 part and a pain to replace but it was worth it! Thanks again!
Chad
Old 11-10-2007, 02:33 PM
datamgrsvc datamgrsvc is offline
I have 2001 Windstar. With info from this site I replaced the blend door motor. I removed the door and cowling below the cup holder that had 4 screws holding it. 2 on each side. I pulled out the cup holder (not removed) and I was able to get to the motor. 3 5/15 screws. fairly easy to get to. The motor was 31.99 from O'reillys plus 7 shipping. The local dealer wanted $78. Thank you for the information. My wife is very happy.
Old 11-10-2007, 04:10 PM
WOW I spent 56.00 from my dealer and no one else carried them.. Thats been I guess a few years now.. So now pep-boys and O'reillys has them. Thats good to know. For the key is to save $$$$$$.... Thanks for your post..
