Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Exterior and Wheels
Exterior and Wheels This is the place for all exterior wheel modifcations.
Old 02-17-2006, 03:57 PM
gstnewb gstnewb is offline
Where do I get this paint??
My 1990 Eclipse GS-T has some faded spots on the front hood and on the rear spoiler. I want to get some spray paint but I can't find this color anywhere. The color of the car is red but none of the stores around here carry that specific red for Mitsubishi from that year. Can I get it online somewhere?
Old 02-17-2006, 04:17 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Where do I get this paint??
Do you even know what the paint code is? Kind of hard to help you unless you know what your looking for.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 02-17-2006, 04:19 PM
G-man422's Avatar
G-man422 G-man422 is offline
you could see if a dealer can order it for you.
G-man422's Avatar
Old 02-17-2006, 05:11 PM
musicman181 musicman181 is offline
when you find the right paint make sure you take it real slow. i screwed my front finder with spray
civics are for suckas
95' eclipse gst
stock turbo
new C.A.I.
programmed ecu
2.0 DOHC manual
greddy bov
im workin on it. slowly but showly
Old 02-17-2006, 08:32 PM
No, can't find the code anywhere. I checked Kragen's paint book and all they have for the paint for Pre-1994 Mitsubishi is Black. No red, for some reason. I will contact the dealer but I think it will be waay overpriced.
Old 02-17-2006, 08:40 PM
The color is the same as this hood in the picture here:
http://cgi.ebay.com/ebaymotors/89-90...39476451QQrdZ1
Old 02-17-2006, 10:07 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
You know it's going to look like shit, even if you do a good job. Spraypaint has a 1% chance of looking as good as regular paint, and that's if it's applied by a professional painter. Plus then you have to put on a clearcoat and if you put on a spray clear then you'll get overspray and orange-peal and it'll look like hell.
95 Talon TSI AWD
97 Eclipse GST
Old 02-17-2006, 11:50 PM
It will definetely be better than what it is now, half white half redish peeling off paint.
Old 02-18-2006, 01:28 AM
After you do it that way, your gonna wish you had done it right the first time.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 02-18-2006, 02:32 AM
Yeah, maybe. I am pretty good with these things and I won't just start spraying like crazy. It will be wet-sanded first to get a glass-like finish and then painted. I will use primer and then the real paint. It won't be like factory paint but I just don't want to attract attention with a half white faded hood, that's all
Old 02-18-2006, 10:50 PM
Don't wet sand it, scuff it with a sotch-brite pad to scuff it up before you prime it. Also use a primer/filler if you're just doing a spraypaint job.
95 Talon TSI AWD
97 Eclipse GST
Old 02-19-2006, 04:08 AM
The main question is, where can I get the paint?? I can't find it anywhere. I bet the dealership will charge an arm and a leg for a single can and I need at least 4 plus the primer and all other materials.
Old 02-19-2006, 02:42 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Ypu can try napa. Some of them mix paint. It's ike $70 for 1 qt. plus you need primer, reducer and clear coat, but it will look 100x better than out of a spray can.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 02-21-2006, 12:33 AM
Yeah, I haven't tried Napa. That might be my only choise left. I even went to the dealership and they told me that they don't carry paint for cars from that year or anything around that period. Go figure.
I will definetely try napa though. First I gotta fix the coolant leak whereever it is. Friday will be a "take everything apart" day and hopefully I can replace everything that needs to be replaced. I hate leaks whose origin I can't see.
1990 Eclipse GS-T (STOCK)
Planned mods: 15 psi boost; turbo timer; blow-off valve; 3" catback exhaust; alum. IC pipes.. for now
