Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 02-17-2006, 12:46 PM
corina07 corina07 is offline
Question Keyless remote
I just purchased a remote for my 2001 chevy impala it has the lock, unlock, horn and trunk release buttons on it but i do not know how to program it was wondering if anyone here could help???
thanks
corina
Old 02-17-2006, 09:32 PM
bigrod118's Avatar
bigrod118 bigrod118 is offline
Re: Keyless remote
I knew making this would come in handy.
lok at you radio, on the flat black part where it shows all the information like staion etc.. do you have a picture in the bottom right hadn corner that has like 2 cd's then says RDS? you will need to know that when you go to look at these how to's
http://www.impalaauthority.com/messa...er_lights.html
Old 02-20-2006, 10:09 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: Keyless remote
FOB PROG (Remote Keyless Entry Transmitter Programming): This feature allows you to match the remote keyless entry transmitter to your vehicle.
To match the transmitter:
1. Scroll, using the SEEK up or down arrows, until FOB PROG appears on the display.
2. Press the PREV or NEXT button to enter the submenu. The current selection will have an asterisk next to it. BEGIN will be displayed.
3. Press the DISP button to start programming. When the message PUSH FOG flashes, press and hold the LOCK and UNLOCK buttons on the first transmitter at the same time for 15 seconds. A chime will be heard to verify the transmitter is learned.
4. Repeat Step 3 for each additional transmitter.
The mode you selected is now set. You can either exit the programming mode by following the instructions later in this section or program the next feature available on your vehicle.
EXIT (Exit Feature Customization Mode): This feature allows you to exit the vehicle customization programming.
To Exit:
1. Scroll until EXIT appears on the display.
2. Press the DISP button to exit programming. A chime will he heard to verify the exit.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 12-11-2008, 07:22 PM
310boy 310boy is offline
Re: Keyless remote
what about if i dont have the original sterio ??? what should i do ? is theres a way ???
Old 12-11-2008, 07:27 PM
wafrederick wafrederick is offline
Banned
Re: Keyless remote
Does not work that way,take it to the dealer and has to be done with the Tech 2 only.The Motor and Mitchell will say to program key fobs with the Tech 2.I have read this on the Mitchell,use the Tech 2 only
