Old 02-17-2006, 10:41 AM
brownsville1 brownsville1 is offline
98 Grand Prix GT
I have a problem with my key not comming out of the ignition, in addition my car is hard to start. The battery needs to be jumped periodically. It seems that there is power drain. HELP!!!!!!!!!!!!
Old 02-17-2006, 11:24 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 98 Grand Prix GT
Are you 100% sure the battery is good. Key stuck in ignition is because of the battery or any possible parasitic drain. Might consider getting the battery tested first before further troubleshooting. Any drain of over 25ma of current will cause it based on battery reserve capacity.
Timeslip 08/12/06
AF Community Guidelines
Old 02-17-2006, 12:06 PM
Thanks for your reply.......I know my battery is drained a bit, but this has occured due to a parasitic drain that I can't figure out.
Old 02-17-2006, 12:17 PM
BNaylor's Avatar
Could be almost anything. The BCM module, low frequency power amp, retained accessory power (RAP) not working, starter/solenoid, etc. Normally to check for parasitic drain you need a grounding bar that hooks up to the battery negative. The ground bar will have test points to hook up a multimeter run in current position. If the draw is over 25mA/30mA then it is abnormal. Find your battery reserve capacity on the label and divide by 4. Basically, you will need to systematically start disconnecting electrical components that could be the cause.
Timeslip 08/12/06
Old 02-17-2006, 02:46 PM
wlkjr's Avatar
wlkjr wlkjr is offline
When my original battery went belly up I couldn't get the key out of the ignition either. New battery and all was well. Have had another new one since but don't remember the key getting stuck.
Old 02-17-2006, 02:47 PM
Thanks a lot.....that's just what I feared.
Old 02-17-2006, 02:49 PM
I'm going to try this 1st should be cheaper
Old 02-17-2006, 03:06 PM
BNaylor's Avatar
Not that I would recommend doing it since you're working fine but disconnect the battery negative terminal. Then take ignition to start. Then back to off. Guess what the key will be stuck/locked in the ignition until you get 12v back to the key release solenoid. That is just the way it works needless to say.
Timeslip 08/12/06
Old 02-17-2006, 05:43 PM
saulgar saulgar is offline
Talking Re: 98 Grand Prix GT
bro check the main fuse box next to the battery an check if the positive wire is well tighteng cuz grand prix did that shit for a while i thought it was the battery but it wasnt try it !!!!
