Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-17-2006, 12:51 AM
ShortyDTP's Avatar
ShortyDTP ShortyDTP is offline
Send a message via AIM to ShortyDTP Send a message via MSN to ShortyDTP
I keep blowing the turbo!!
aww!!! i am soo piss, i don't know what the hell is going on!.
ok i had a small 16g for about 4 months. and for the past month I been hearing a blender type of sound , ti'll i notice the turbo had lots of back and foward shaft play. next day ,broke the oil seal. ok no problem i had a 14b as a replacement. install it prime it, and stared it up ... perfect.
later that afternoon, i was hearing the blender kinda sound again ,this time quite louder.... 10 minutes later.....no more boost.
after that , after 3 weeks of looking for another 14b , i finaly found with no play and low miles, aww great! istall it............ blew same freaking day!!!! I DON"T KNOW WHAT TO FUCKING DOOO!!!!!
Help! do oil pressure has someting to do???
I don't have an oil press gauge, but stock gauge show a little above the middle at wot.
P.S I replaced my oil everytime i replaced the turbo.
Any ideas of what the hell is going on????
P.S anybody has another 14b for sale??? please let me know!!!
Thanks!!
Jose
HOLESHOT PERFORMANCE
91 Laser Rs 471 whp at 22psi pump scm-6152e
98 Eclipse GST 11.4 @ 121mph Stock T25/nitrous
Jose Mendoza
Old 02-17-2006, 01:15 AM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: I keep blowing the turbo!!
you did replace the oil filter everytime too, right? I hope you're using a quality filter. Look for an oil leak, a boost leak could also overwork the turbo and kill it pretty easily.
now - 2000 civic
soon - 2002 is300
Old 02-17-2006, 01:38 AM
ShortyDTP's Avatar
yes oil + filter and "mobil" too! no oil leaks what so ever, nothing around turbo nor nearby. boost ..... it holds 30pounds for more than 30 seconds
Jose Mendoza
Old 02-17-2006, 07:37 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Make sure the oil feed line isn't plugged and starving the turbo of oil, it sounds like thats what your problem is.
95 Talon TSI AWD
97 Eclipse GST
Old 02-17-2006, 12:15 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
I have a 14b I want to get rid of if you want it
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 02-17-2006, 12:38 PM
ShortyDTP's Avatar
i cleaned the oil line everytime i install each turbo. i am worried that i have a pressure prooblem.
Jose Mendoza
Old 02-17-2006, 12:46 PM
Does the pressure every drop any lower than a bit below the middle? I don't see how a pressure problem would starve JUST the turbo, but you could replace the oil pump if you really are up for the work. But MAKE SURE that oil feed line is clean.
95 Talon TSI AWD
97 Eclipse GST
Old 02-17-2006, 12:51 PM
blk_srt's Avatar
It could be a volume problem where theres enough pressure but not enough total volume to supply oil for everything, in that case it would be a pump. but if its low pressure then you need to start looking at your main bearings for wear
Mods:
