97 XJ Intermittent Start
I'm experiencing starting problems with my 97 XJ. When I turn the ignition, nothing happens. I hear the starter relay click, but it doesn't turn over. If I wait 5-30 minutes, it will start right up. I've replaced the started relay and NSS, still no luck. Any thoughts? Appreciate the help!
Re: 97 XJ Intermittent Start
my '93 GC did that a couple of times, it ended up being the wires that attached to the starter came loose...
Black 99 Jetta GLX VR6 Black 92 BMW 525I Blue 95 GMC Jimmy SLT 4.3L VORTEC V6 (Sold... Junk) Green 98 Jeep Cherokee SE (totaled Electrical fire) Red 95 Jeep Cherokee Sport (Gone) Green 93 Jeep Grand Cherokee Limited (for sale) [email protected] "Racing a ricer is just like competing in the special olympics, even if you win your still retarded" |
Does this happen when cold, hot, both, in between?
My 97 had a bad switch, but I would start with Battery and cable testing, including ground. I mean test, not buy and replace. Get a Digital volt-ohm meter.
i had the same problem with my xj, i had to keep a long crowbar in the back because i would have to bang the starter in order for it to start. turns out it was the wire connection. wacking the starter might be a temperary solution you can try
ps. i eventually had to replace the starter afer accedentally cutting the wire while wacking the starter. so be carful... |
