| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Hello. Can anyone give me an ok price to pay for a valve job and resealing? If so that would be great. The heads are 350 stock heads. This is not including the cost of taking them off because they are already off of the car. Thank you.
Anything is possible through Christ our Lord. 1980 Camaro: Base coupe sleeper with 350 4bolt main (stock bore, double humps, 480 lunati cam, flowtech headers). Stock 2.73 open rear (changing next month to 4.10 mini spool). |
Re: Rebuilding the Heads.
What are you looking to do for the heads? If you go to www.summitracing.com you can look up the valves, valve springs and anything else you need just to get a rough estimate. All you have to do is estimate the time and labor and you would have yourself a nice little ballpark figure.
1969 Olds Cutlass 1985 Olds Cutlass 2000 Ford Ranger 2001 Jeep Cherokee Sport |
At our shop, a "basic" valve job consists of tearing them down, cleaning (thermally), magneflux, measure everything, grind the valves and seats, and reassembly. $140. Resurface (usually needed) is $90 for the pair. If the guides are beat, we charge $119 labor to install the whole set (16). The price of the guide will vary depending on material used.
Parts are replaced as necessary, and are extra charge. The seals are in the "head set" (all the gaskets necessary to change both heads). If you buy the "cheap" or "early" set, the seals might not be in there. This information can be geographically sensitive, as shops in some parts of the country are higher than others. I supply our prices for comparison. We're 45 miles SW of Richmond, VA. With all due respect to Summit, your local machinist will know more what you need, and usually be competitive in price. Jim |
Matt,
DId you get the PM? I tried to return one to you, but I have no idea if it went through. I can't receive PMs for some odd reason. Computer goes to "Cannot Find Page" page... E-mail me directly. [email protected] Jim |
I just got a chance to get to it. I have email you the same thing I sent in my PM. Thanks for being on the look out.
