Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 02-16-2006, 11:49 PM
master hec0's Avatar
master hec0 master hec0 is offline
Send a message via MSN to master hec0
1992 mgm block heater
does the 1992 mgm have a block heater in it if so ware is the plug located if not how much wiill it cost to install it
Old 02-17-2006, 09:33 PM
Re: 1992 mgm block heater
anyone kno how to install one?
Old 02-18-2006, 01:20 PM
kreflo's Avatar
kreflo kreflo is offline
I think a block heater would be an optional accessory. If the car had one you would see a male electrical plug near the grill or front of vehicle. Im sure you could find at autoanything.com or somewhere similar(autozone) store or website. Basically the block heater is installed in one of the freezeplug holes. If you are mechanically inclined you would have to drain anti-f and remove a freezeplug and install the block heater. I would guess a shop would install one with a flush for about $200.00.
Old 02-18-2006, 03:21 PM
i have a chilton manual but it doesnt state anything about installation of block heaters got any ideas ware i could go to find some instructions on installing it
Old 02-18-2006, 06:29 PM
kreflo's Avatar
its pretty straight forward. first drain coolant. second remove freezeplug on block(get a freezeplug tool from autozone for free use). third install heater/freezeplug element and torque to spec. refill coolant and run electrical extention wires(couple of wire ties). checkout ebay theres one for 20 bucks and 8 bucks shipping. ford part for a newer mustang should be the same part #. call dealer and ask if that is the right part #. GO TO EBAY AND TYPE mustang engine block heater. gl.
Old 02-18-2006, 06:32 PM
what i mean is ware do u put it because its optional so their must be a spot to add one
Old 02-18-2006, 06:39 PM
kreflo's Avatar
you have to remove a freezeplug in the engine block. and the heater is the plug
Old 02-18-2006, 06:40 PM
kreflo's Avatar
i have instructions on my 1996 mgm cd repair manual i can e mail you
Old 02-18-2006, 06:42 PM
ok e mail it to me i guess a v8 motor is a v8 motor no matter the year right?
Old 02-19-2006, 09:28 AM
kreflo's Avatar
i think so but i still would check to make sure you get the right internal clearance with the block heater that you get, i believe there are two kinds. I sent the installation instructions and freezeplug removal info to your email heco, Good Luck. Let me know how it comes out i might install one myself.
Old 02-19-2006, 11:37 AM
HEMIDAZE's Avatar
HEMIDAZE HEMIDAZE is offline
In the past I have seen heaters that install in your radiator hose. Very easy installation.
Old 02-19-2006, 11:52 AM
il be doing the instalation in probally 2 weeks im gonna go get a used block heater for 40 dollars from a crown vic/grand marquis/towncar at a junkyard
Old 02-19-2006, 07:46 PM
i scratched that idea my cars too crapy for me to spend even 100 dollars on a block heater
Old 02-19-2006, 10:05 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
why is it to "crappy" whats the matter with it
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 02-19-2006, 11:14 PM
well i have a mega low buget on the car and i dont wanna pay alot for a block heater plus iv decided it doesnt need it
