Old 02-16-2006, 10:44 PM
reza51 reza51 is offline
The Daytime Running Light
Hi
I have a ford taurus wagon 1997 3.0L V. When I turn my car off, the Daytime Running Lights are still on. I had to remove the fuse to turn it off. How can I fix this. I am in canada and I need the DRLs.
Thanks
Old 02-16-2006, 11:09 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: The Daytime Running Light
A quick search of the Taurus forum resulted in a few threads that should help you out. It appears the typical solution is to replace the DRL module.
http://www.automotiveforums.com/vbul...archid=1429177
-Rod
Old 02-16-2006, 11:16 PM
Red face Re: The Daytime Running Light
i already tried to search but could not. can you give me some keyword for search.
Thanks
Old 02-17-2006, 01:17 PM
shorod's Avatar
SHO No Mo
Hunh, I guess that link didn't work for some reason. I believe the keyword I searched for was "daytime."
You may want to try the following links:
http://www.automotiveforums.com/vbul...hlight=daytime
-Rod
Old 02-17-2006, 01:42 PM
Thanks for reply. I found some good information in the following link:
http://www.v8sho.com/SHO/DaytimeRunningLights-Diag.htm
It is for SOHO but everything is same as Taurus.
I recommend it to anybody who has problem with DRL.
Now I am looking for a used DRL for my taurus 1997. As sson as i install it, i let you know of the results.
Reza
