Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-16-2006, 10:35 PM
c_elliott_14 c_elliott_14 is offline
Gauge lighting problem
I recently had some autometer c2 gauges installed by a certified technician. the problem is that he said no matter what he tried the dimmer on the autometer gauges was reversed from the factory dimmer switch. for example if the dash dimmer switch is brightend the autometer gauges would dim. if the dash gauges were dimmed the autometers get brighter. has anyone else had this problem hooking up their aftermarket gauges to their stock system. Or is this service technician not know what he is doing
Old 02-16-2006, 10:37 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: Gauge lighting problem
I would suggest just hooking them up either directly to the light switch so when the lights are on so are the guages or do what I did and just run them directly to power so when the car is running my gauges are lit
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 02-17-2006, 10:34 AM
ned032002's Avatar
ned032002 ned032002 is offline
I agree that's how I had my reverse Glow Gauges hooked up, straight through the dimmer.
Old 02-17-2006, 12:45 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Velkommen to ze automotiV forums.
Utilize the search button and the sub-forums, and we'll get along just fine
The daily driver. The weekend cruiser. The lazy shop hog.
Old 02-19-2006, 02:11 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Considering a car has dc power they could be switched (power to ground and ground to power) other than that I'd think it was a manufacturers defect.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
