Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-16-2006, 10:30 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Why do some cars make more power on smaller injectors?
I got to thinking about this and I relized that dsm's seem to use larger injectors than a lot of cars when dealing with high hp. For example stock 4g63 injectors are 450cc but I have a buddy thats making close to 300whp in his turbo civic and hes running dsm 450s and he said he has plenty of room left on them. Also I've seen skylines and supras making 500+whp on like 460cc injectors. Whats up with this?
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 02-16-2006, 10:38 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: Why do some cars make more power on smaller injectors?
engine size, desired air / fuel ratios, impedance of injector
plenty of reasons
now - 2000 civic
soon - 2002 is300
Old 02-16-2006, 10:40 PM
blk_srt's Avatar
I can understand impedance, but I would think if you go with a larger engine you would need more are and consiquencly more fuel. To me making 500+hp on injectors smaller than a stock dsm just seems a bit weird
Mods:
Old 02-17-2006, 06:48 PM
Whathits14 Whathits14 is offline
also rember that the skyline has MORE injectors...My 450s maxed at 16psi on an EVO III so I cant really explain why the honda is makine 300whp on 450s....different displacement will chew less gas, as will less boost.....
Need a GOOD 6-bolt engine?
http://www.totaljdm.com/?id=19334
'95 Talon Tsi
EVO III GT, supporting mods, not running
Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped.
Old 02-17-2006, 11:05 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Yeah, each injector needs to supply X amount of fuel for Y amount of air. Though the Skyline has more displacement and more cylinders, its only a 2.6 right? That means that each cylinder volume is .433L and the 1.6 Honda engine has .4L compared to the 4g63 that has roughly .5L per cylinder. See what I am getting at? Each cylinder from those two cars require less gas, so smaller injectors will suffice. I know theres those other things, but this is what I think. I thought about it for quite a while after I got my modified mag a couple weeks ago, and this is what makes most sense to me.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 02-18-2006, 12:13 AM
blk_srt's Avatar
That makes alot of sense, but it still seems weird to me that other cars can produce so much more power then DSM's. I mean granted more cylinders=more power but even Honda's, all well, I'll stick to the 4g anyday(unless I find a cheap mkIV supra, then I'll have a 2jz also )
Mods:
