engine question
If you get a 350 motor out of a truck (1993-1997)is it the same as the lt1. I think you could get a truck 350 a lot cheaper than if its out of a camaro.
Re: engine question
im 99% certain they are different
Re: engine question
i think one is a 4 bolt main and one is a two bolt main.
95 Z71 Silverado 4x4 ext. cab Mods- Flowmaster Exhaust,Intake |
Re: engine question
They're different, I think a truck 350 Lt1 is crappier than one out of a Camaro, im not sure on that, but I DO know that they use different heads.
Re: engine question
Truck had iron heads and the LT1 had aluminum heads.
Pretty sure the blocks were the same...but past that, they were pretty different. Not sure if that is even right though.
1999 Pontiac Trans Am WS.6 #1747 Stock'ish' |
Re: engine question
Maybe a caprice engine would be the same and cheaper, or would they have iron heads too?
![]() '91 RS, forged LT1, GTP heads, blower cam, AFR Hydra-Rev kit, ram air intake, SLP 1 3/4 headers and 3" y-pipe, 3" Dynomax exaust, Yank 2800 TT stall converter, Strange 3.73 gears with Zexel-Torsen LSD, ect, ect... |
Re: engine question
the impala's are the same, and i think the caprice are the same also.
Re: engine question
the truck 350's are normal SBC's with swirl port heads and TBI.
Re: engine question
Hurrah for Geno and his vast sea of knowledge. Plus, I was going to say the same thing.
1998 GTP sedan Mods:MPS 3.4|180Tstat|PowrTuned|AL104's|SSAC's|DIY HAI|F-body's|GMPP H.K.|Gen2 SSC|KYB GR-2|Hand e-brake|Bucket Rear Seats Soon:Appearance mods|some secret stuff|Audio stuff Future: 12 second DD |
Re: engine question
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune. |
Re: engine question
He probably meant all else besides that, for that is pretty much the only difference.
Re: engine question
it looks like they have different intakes from pictures I seen
Re: engine question
I also think the oil tank is bigger
Whats the difference in heads iron aluminum heads |
Re: engine question
Iron heads hold more heat thus they can't handle as much power due to pre-detination.... aluminum heads dont hold the heat so they can create more power.... and if you get down to it the weight factor... etc.....
![]() 1995 Camaro - Z28 - M6 - Hardtop 2007 GMC Sierra 2500HD SLT Classic -R.I.P. Andy (Hypsi)- |
Re: engine question
The Caprice and Impala LT1's have different accessory brackets due to a different style power steering unit and the 94 Caprice/Impala LT1's have the newer style vented opti as well which wasn't used til 95 in the Vettes and F-bodys. The exhaust manifolds are different as well and I believe that the B-body uses 22lb injectors instead of the 24lbs used for 94 + Vette and F-body LT1's. So its not just heads that are different.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
