96 Skylark 3.1 V6 code PO341
Got a 96 Skylark with the 3.1L V6 and it has code PO341: crankshaft position sensor circuit range/performance. My question is should I test the sensor in some way first? Is this a common problem? Just replace the sensor? It is difficult to replace? I cleared the code once before and it comes back after two drive cycles. Thanks for all your help!
Re: 96 Skylark 3.1 V6 code PO341
Cam sensor signal circuit, not crank sensor, look at the connector and see if you see a problem, loose, corroded?
