Old 02-16-2006, 06:18 PM
anthony90si anthony90si is offline
removing rack and pinion
hi guys i am gonna change the rack and pin on my car and was just wondering how big of deal it is. i see the 4 bolts holding it in place but how exactly so i disconnect the steering from the rack and pinion
thanks.
stock b18a1 14.97 @ 92 mph
Old 02-16-2006, 06:48 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: removing rack and pinion
It's really just those bolts, maybe a couple on the input shaft, and the linkages on the knuckles....
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 02-16-2006, 09:27 PM
ya but how is the steering shaft attached to the rack and pin. ?
Old 02-16-2006, 11:03 PM
FrodoGT's Avatar
It has splines, the column will come apart from the box, but to get it out you have to remove your shift linkage and exhaust. That requires some pins and clamps in the linkage...
Current project:
Rio Red 91 hatch.
Old 02-17-2006, 04:45 PM
so bacially everthing is done from under the car? i am gonna give it a shot tonight. thanks dude .
Old 02-17-2006, 08:51 PM
FrodoGT's Avatar
If you can find a service manual to download, I have one but canr remember where I got it....then youll see that theres a cover under the dash you need to take off, I think theres something there, and under the car its pretty much all there, just loosen the sahft and slide it out once its all unbolted, I had my car on a lift today and looked at it, Im pretty sure youd be able to get it out without disconnecting the shift linkage, as for the exhaust Im not sure, Im running a custom tanabe setup....
Current project:
Rio Red 91 hatch.
Old 02-25-2006, 05:41 PM
ya looks like i got to take off a bolt uner the dash to seperate the rack and pinion from the steering column
Old 02-25-2006, 08:58 PM
FrodoGT's Avatar
Yeah I think I metioned that, maybe not but Im too lazy to scroll up...
Current project:
Rio Red 91 hatch.
Old 02-26-2006, 05:48 PM
yes you did mention it. i just confirmed it. thanks dude!!
Old 02-26-2006, 09:35 PM
FrodoGT's Avatar
Anytime...
Current project:
Rio Red 91 hatch.
