Old 02-16-2006, 07:16 PM
demonadark demonadark is offline
Color pics of instrument cluster panel install
Hi My radio lights for the time/display is gone. i was told here it was the instrument panel cluster? Does anyone have a step by step for replacing it? 98 GP GT
Old 02-17-2006, 08:48 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Color pics of instrument cluster panel install
Shine a flashlight toward the display, if you can read it with the flashlight, it's the backlight bulb burnt out (relatively simple fix). There are several threads on here regarding this issue, just use the search function. If you still can't see the display with the flashlight, then the LCD itself or the circuit board controlling it are bad, and radio replacement is the best solution, as the repair isn't a DIY job and the repair is pretty costly.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 02-17-2006, 10:26 AM
BNaylor's Avatar
BNaylor BNaylor is offline
There is a lamp for the radio time display which burns out. The dash panel and radio have to be removed to replace it. The part # is 16208443 available at the dealer. Cost approximately $8.00. Substitute bulbs are available at Radio Shack and mentioned in the R&R procedure below.
http://users.adelphia.net/~bpaskevic...amp_repair.htm
And here is the procedure to get the radio out:
http://www.carstereohelp.com/stereor...andPrixSt2.htm
Timeslip 08/12/06
AF Community Guidelines
