Old 02-16-2006, 07:03 PM
Zack614 Zack614 is offline
Ignition lock problem
I just replaced the ignition key switch on my 1987 Laredo but it still won't go into the lock or accessories position. Any ideas or help, Please??????
My new job requires me to be able to secure my vehicle from theft.
Thanks in advance for any help
Old 02-19-2006, 03:22 PM
Saudade's Avatar
Saudade Saudade is offline
Re: Ignition lock problem
Are you referring to the switch at the base of the column?
If so, there is a cable that runs up the column and mounts to a bracket that sits on the stud that the switch bolts on to. The bracket is slotted so you can adjust it. You'll need to lossen the nut and slide the bracket toward the wheel, then snug down the nut. Do NOT overtighten. Then try the accy position. If it's still not right, you may have to lossen and readjust again.
You'll need to remove the lower dash panel to get better access but should not have to lower the column. However, it's still a tight fit.
