Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-16-2006, 05:35 PM
madrox68 madrox68 is offline
Send a message via Yahoo to madrox68
Question fuel system
how do you install a aftermarket fuel pressure regulator on a 95 eclipse gs (its a jdm regulator and they didnt include instructions)
Old 02-16-2006, 08:12 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
Re: fuel system
ok pretty easy replace the O-ring on fuel pressure regulator with a new one and coat it lightly with clean, thin oil.
Insert the regulator straight into the rail, then check that it can be rotated freely.
If it does not rotate smoothly, remove it and inspect the O-ring for deformation or damage.
When properly installed, align the mounting holes. If equipped, install and tighten the retaining bolts to 8 ft. lbs. (11 Nm). If equipped, install the regulator retaining snapring.
Connect the fuel return hose to the pressure regulator.
Install the vacuum hose to the fuel pressure regulator.
If removed, connect the PCV hose to the valve cover. On 1.8L engines, also connect the breather hose at the opposite end of the valve cover.
Connect the negative battery cable and pressurize the fuel system. Inspect for leaks. should be easy good luck later
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 02-16-2006, 08:16 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: fuel system
Watch that regulator carefully, my friend had one of those "jdm" regulators on his gsx and the pressure actually went down on the gauge when the rpm's went up, really just watch for leaks, it would be a shame to have a fire because of a little leak
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 02-16-2006, 08:21 PM
Re: fuel system
ok thanks ill try it
Old 02-16-2006, 08:26 PM
Re: fuel system
o yah i almost forgot how do u adjust the pressure
Old 02-16-2006, 08:27 PM
blk_srt's Avatar
Re: fuel system
Should be a screw on the top and you can adjust it with
Mods:
