Problems after installing clutch
I just installed a clutch and flywheel on my 92 Integra. When I go on first gear the car shakes/vibrates for a couple seconds and then when the car gets rolling it goes away. Same thing happens when I go on reverse. I haven't really adjusted the cable yet. I just took it for a test drive and parked it. I was wondering if that's the problem or could there be something else?
I've been trying to get it started for two weeks and when it finally starts, this happens. Man, this is frustrating. Any help would be greatly appreciated. Thanks in advance. Clutch = Clutchmaster Stage 1 Flywheel = ACT 12.5 lbs
BennyBenster |
Re: Problems after installing clutch
its called clutch chatter and most of the time results because of a dirty input spline, did you clean the spline before reassembling?
![]() 26 PSI anyone? |
Excuse my ignorance, but which is the input spline?
BennyBenster |
Or the flywheel........
![]() ![]() ![]() R.I.P 00' ITR #479 ![]() 1996 GSR: Built Bottom - Built Head - Big Injectors - Big Turbo - Computer Thingy - 500+ whp ![]() *2-6-06* Waiting for the Full-Race Stg 3 with GT35R .82 a/r Upgrade and Nitrous Express NXL ![]() http://www.cardomain.com/ride/2241056 |
oh this is making me feel great....i'm putting a clutch in my GSR in about 3 weeks. I bought an Exedy 3 pk and ACT 8lb flywheel......i hope i don't have any problems...good luck w/ yours!!
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR |
they can become dirty and need to be wiped off but whatever you do do not put any kind of lube on the spline, it goes back together dry
what? I've always been tought to lube the shaft, otherwise the throwout bearing can become hung up on the shaft in the future??? I've never had any problems with lubing the shaft lightly, and I have had problems with one that I didn't lube when I was a kid... it got hung up, and after I tore it back apart and lubed the shaft it was fine.
Old: 1993 Acura integra gs-r New: 1998 chevy BlaZeR2~ AKA "Jeep recovery device" Newer: 2007 Honda CB900F "919" |
Ok, I know exactly what you're talking about and no I didn't clean it. I didn't lube it either because I read somewhere not to lube it but there's nothing saying to clean it. Looks like I have to take it back apart...SHIT! So close yet so far.
About the flywheel...is there anything that needs to be done to a brand new flywheel besides making sure it has no grease on finger prints on it before installing? I made sure to wipe it with a clean rag before installing the disc and pressure plate. Same thing with the pressure plate, wiped down with a clean rag before installing. Thanks for all the replies.
BennyBenster |
yea, i hear ya about the so close yet so far thing, lol
as for the flywheel you should be good to go, good luck with it!
Ok, so when I pull the tranny off and clean off the spline, should I also clean the area that the spline slips into since I assume that should have dirt in it also?
BennyBenster |
