Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 02-16-2006, 02:13 PM
rontomed's Avatar
rontomed rontomed is offline
Question Still having 2nd to 3rd shift problems.
Shifting from 2nd to 3rd still hangs up in 2nd at times. Someone told me a way to replace the old fluid without having to drop the pan is to disconnect the transmission fluid line at the radiaitor, measuring the amount drained and replacing it with fresh fluid. I would repeat the process after driving it for several days to replace more of the old fluid. Only a trickle flows out when I disconnect the line from the radiator. Should I start the engine so that the transmission will pump the fluid out? Will this damage the transmission? Should it be shifted to neutral?
Old 02-20-2006, 08:26 AM
TurboDuck's Avatar
TurboDuck TurboDuck is offline
Re: Still having 2nd to 3rd shift problems.
You really should drop the pan. Not only will it drain better / faster, you can look in the bottom of the pan and see if there is any shrapnel in there. It's not really as bad a job as you'd think. Use a big / wide catch pan. I start by removing all of the rear pan bolts, then loosen the bolts on the sides starting from the rear. I always make sure the pan starts to drop before taking all the bolts out, otherwise you will have a mess on your hands. (Self) Once it starts to drop, it will pretty much drain from the rear. Then you can finish removing it.
Old 02-20-2006, 05:33 PM
dadof4s dadof4s is offline
Send a message via AIM to dadof4s Send a message via Yahoo to dadof4s
This would be akin to removing an oil filter and then running the motor to drain your motor oil. You could do serious damage.
Old 02-23-2006, 10:03 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
I agree, if you run it for too long. However if you slightly overfill the trans before doing it, only run it long enough to get some out, then refill and never let the level get too low, it should work ok. Of course there's the big "BUT", which is if the pickup sucks air it's definitely a bad thing.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 03-02-2006, 09:50 PM
troy1 troy1 is offline
AF -Advisor
Most of the time a delayed 2-3 shift is an internal seal issue. The seal in question is the inner seal on the direct drum(3rd) the grove is cut to deep and as the seal ages and shrinks up it can no longer seal properly.
Old 03-03-2006, 05:52 AM
I have had older pickups with shift problems. A can of Berryman's B-12 poured into the auto trans. and allowed to sit overnight will cause the seal to swell and elimanate any shift problems due to the seals.
Old 03-05-2006, 11:06 AM
rontomed's Avatar
Smile Re: Still having 2nd to 3rd shift problems.
I am being very careful to drain only 4 quarts at a time, filling a gallon jug each time. This takes only a few seconds of running the engine. I've done this 2 times, driving the truck for several days in between drainings. My shift problems appear to be gone. Thank you all for your postings.
Old 03-05-2006, 11:12 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
What was it really doing? Would it slip in between the 2-3 shift or would it just hold 2nd for a long time?
Sometimes I think the way my automatic shifts is weird...
My Mopars
Old 03-06-2006, 08:32 AM
rontomed's Avatar
It would hold onto 2nd to long. It never slipped. Also, you have to run the engine in drive with the parking brake on for the fluid to pump through the tube.
Old 03-06-2006, 12:16 PM
sneakybert sneakybert is offline
most of the time to repair this issue the trasmission needs to be overhauled . The root cause is worn out front clutch seals.
Old 03-06-2006, 01:05 PM
AF -Advisor
Yes Direct (front clutch) inner seal is the problem. Please don’t waste to much time a money with additives and fluid changes. My 95 dakota does this very samething. I switched to dextron III which helped but still a very small delay. I have yet to pull it out and rebuild it but the direct clutches in mine a yours will be burnt because of the inner seal.
Old 06-29-2007, 12:09 AM
rontomed's Avatar
Update. I had a transmission shop drop the pan & replace the fluid, gasket & filter. The tech showed me that he removed the original filter & gasket from my transmission. This was at 125,000 miles. This is my daily driver & my transmission is still shifting well.
