Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 02-16-2006, 11:56 AM
ace8077 ace8077 is offline
Send a message via AIM to ace8077
Question Changing Oil Pump on 99 Envoy
Anyone know how difficult it is to change this out? I'm not an ASE level mech. I'm about one level above changing the spark plugs...lol
I was just wondering if there is a site with a diagram on the engine so I know what I'm getting into. Thanks <the newbe>....lol
Old 02-16-2006, 03:51 PM
maxwedge maxwedge is offline
A990 racer
Re: Changing Oil Pump on 99 Envoy
4.3 has been the same for years, although I question why change the pump, autozone.com/repairinfo should have the info, maybe not for 99 but the older ones are pretty much the same.
Old 05-27-2006, 07:45 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Disconnect the transmission from the bellhousing
Disconnect the motor mounts and any related sensor/harness wires
Lift engine out of compartment
Drop oil pan
Use 10mm socket to remove both retaining bolts on the oil pump
Install in reverse. Pack the oil pump gears w/ bearing grease prior to installation
After installation use a drill through the distributor hole with a priming adapter and spin the oil pump till it's primed.
Reinstall distributor
Reinstall engine, harness, bolt engine back to transmission.
