Old 02-16-2006, 10:21 AM
daveid daveid is offline
86 honda
i have posted here before about my honda and fixing it and how it had no spark. Well i have been trying to pin point what part to fix and so forth, and i just couldnt belive that all of a sudden with no signs, my car wouldnt get any spark any more.
SO for a few days i kept going out there trying to start it, and i find something wrong with it causing the no spark. To make a long story short, i didnt replace any thing on it its been about 2 months now. I went out yesterday, and the car started right up.
Any suggestions on how and why this happend? I like that it started and all, but i just want to make sure that i dont get stuck somewhere.
thanx
david
Old 02-16-2006, 11:28 AM
jimmy[the]gent's Avatar
jimmy[the]gent jimmy[the]gent is offline
Re: 86 honda
sounds to me like its your ignition coil
Tommy, you gonna let him get away with that?
Old 02-16-2006, 05:08 PM
jveik jveik is offline
Re: 86 honda
its an 80's honda lol... when you say you have no spark, you actually have no spark or are you just assuming because it wont run? if so, i would make sure that the choke isnt messed up... spray some starter fluid into the carb and it should start right up... im driving a carbureted 88 accord right now and i have a problem with the choke closing too much i believe and then it wont let any air thru and the engine wont start... i sprayed starter fluid and kept the butterfly valve partly open with a screwdriver and it fired right up. At least i will be done restoring my chevy truck soon so i can put that pile of crap honda in a u-pull it before it gets any uglier...
Old 02-17-2006, 10:35 AM
Re: 86 honda
ya, i had no spark. I double checked it too just to make sure. Ya, i have had a problem with it starting a lot, then i upgarded the battery and had no problems. A week later, this happened.
Is there anything i can do or a shop can do to make sure this doesnt keep happening?
tahnx
david
Old 02-18-2006, 01:54 PM
Re: 86 honda
ok, car was running good the past few days and everything, and i go outside this morning, and it wont start. I alawys have this problem when its around freezing outside and it was about 31 degrees this morning. I have a new battery in there too that is 850 cca. Anyone know what i can do to fix this?
thanx again
david
Old 02-23-2006, 08:51 AM
TheMan5952 TheMan5952 is offline
Volvo Guy
Send a message via AIM to TheMan5952
Re: 86 honda
Have you tried changing the coil, or cap and rotor? I'd try with the simple things first.
-Joe- '02 Volvo S60 T5
Sold!1993 volvo 850
Intake, Exhaust, Springs, Shock, I.C.E.
Old 02-23-2006, 02:01 PM
mazdatech177 mazdatech177 is offline
Re: 86 honda
one word... ignitor. its inside your distributor and frequently goes bad on 80s hondas. go to honda parts and ask for one... it shouldnt be too expensive
Old 02-23-2006, 02:14 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: 86 honda
I agree with mazda tech. Also check your ground cable, the one on the water neck next to the distributor.
