Old 02-16-2006, 01:14 AM
Scotteru33 Scotteru33 is offline
Bad Synchro?
I recently just got my car back today after having a new clutchmasters stage 1 clutch put on, new u-joint, and driveshaft mounts. I had all the work done at Sound Performance and they did a pretty good job. A few weeks before I took my car to get a new clutch I had the dealer look at my clutch master and slave cylinder. They said that the master cylinder was in so so shape and that it would probably have to be changed soon. All my gears shift like butter except 2nd is a little notchy/rough. I was wondering if its a synchro or the master. I also think I had a trans flush at my 60k and right now I have 75k(the car doesn't get driven a lot so that was probably two years ago;i need to check with the dealer's records). Also has anyone had good results with a trans flush or additive that fixed a nocthy gear.
Old 02-16-2006, 09:43 AM
sLADe781 sLADe781 is offline
Re: Bad Synchro?
I was having grinding issues in 2nd and a little bit in 3rd as well. I changed my tranny fluid to BG Synchro Shift II and it shifts a lot better. From time to time I still get some grinding but not as much as before. I think that'll just extend the usage of whatever's wrong but sooner or later, I'll probably have to get it fixed. And I would think it's the synchros but I'm not completely sure.
Old 02-16-2006, 01:41 PM
Igovert500's Avatar
blue + red light magnet
Re: Bad Synchro?
It is most likely your synchro, not the master. Master cylinders wouldn't affect just one gear. And I don't know how a dealership could label the master so so. Of course they will say it needs to be changed soon, that is how they make their money. Dealership = Stealerships. Don't trust them.
Anyway, many have had improved shifting with drivetrain oil changes. And if you have some basic tools and a few jackstands you can do it yourself.
http://www.stealth316.com/2-awddrainfill.htm
Don't know if you are awd or fwd, but you get the basic idea. Redline, royal purple, synchro shift 2, any premium gear oil will help dramatically.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-16-2006, 08:17 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
Re: Bad Synchro?
eventually you will have to get it fixed
when time comes
http://www.kormextrans.com/co_info.html
ask for blocking rings
Old 02-16-2006, 09:54 PM
Re: Bad Synchro?
Would I order the blocking rings or the trans synchro rebuild kit (1&2 gears) from supercar-engineering.com/sc2/index.php?cPath=4
Old 02-16-2006, 10:09 PM
youngvr4's Avatar
STREET RACING GURU
Re: Bad Synchro?
dont know much about that kit, i do know its the blocking ring that need replaced. not sure what they mean by friction ring
