Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 02-16-2006, 12:14 AM
PuNjAbi DrAgOn PuNjAbi DrAgOn is offline
Auto to Manual Conversion
I got a great deal on this automatic mercury cougar 1999. But i was wondering would it be worth converting it into a 5 spd manual. If anyone could help me by telling me the costs it'd be great THANKS.
Old 02-16-2006, 05:52 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: Auto to Manual Conversion
MTX75 Transmission $1600?new $~700used
Clutch Disc $100.21 Plate $103.20 F7RZ-7550-AA & F7RZ-7563-AA
Clutch Slave cylinder $73.84
Flywheel $94.48
Left half shaft $150?
Right jack shaft $50?
Clutch Master Cylinder $29.19
Clutch Pedal Assembly $178.62 F7RZ-2455-AA
Clutch Hydraulic line upper $15
Clutch Hydraulic line lower $15
Clutch fluid supply line $5
Mount-fender side $85.22
Mount-tranny side-left $41.25
Mount-tranny side-right $40
Mount-cross member side-right $36.97
Shift Tower Assembly $72.97 XS8Z-7210-BB
Shift boot $29 regular $99 leather
Bolts- Clutch to flywheel $2
Friction Modifier $3.60 XL-3
Crossmember $450
Shift cables $45
3 quarts Mobil 1 synthetic ATF $15
Vehicle Speed Sensor-mtx $50
134Kohm resistor $1 Radio Shack
As you can tell, this has been discussed before on the cougar forums at www.newcougar.org
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
