Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-15-2006, 10:15 PM
One4uonly One4uonly is offline
1991 Rodeo fast idle
I have a 1991 Rodeo 5 speed with 170,000 miles on it. Recently the idle is going crazy, running around 3000 rpm while driving or when stopped. After driving it floods when shut off. I can't get the idle to go down. Anyone know what may be the problem?
Thanks so much
Old 02-16-2006, 08:17 AM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
Re: 1991 Rodeo fast idle
Typical idle problem that just go up and down by itself is usually caused by a bad TPS (Throttle Position sensor) and another possibility is the IAC (Idle Air Control) solenoid. Both are usually located in the throttle body.
Old 02-23-2006, 01:40 AM
That worked!! Thanks so much. Now I am tackling why the "check engine" light is on..Again Thank you!
Old 02-23-2006, 10:12 AM
directory's Avatar
directory directory is offline
let us know what you come up with--as far as the codes. we will try to help.
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
